Running Probs SonicStage 4.0
baghead
<_< Having just downloaded Sonic stage 4.0 the program runs for about 1 minute and then freezes, I have to close it via task manager, and start again.
Has anyone else had any similar problems or know anything about this!
If you are referring to the download not installing SS4, delete your downloaded file, and run another download. If you are referring to the installed program, Then I would uninstall it, reboot, then reinstall. And maybe even a combination of both procedures. Could be a bad download or a bad install, or both. Also, try closing as many open processes as possible when running it and see if that helps. Good luck.
