Vespa Posted July 25, 2006 Report Share Posted July 25, 2006 Hi everyone,Just thought I'd get that first part out of the way . I remember reading about using SS to transfer tracks at rates other than original Hi-LP, Hi-SP, etc. I've done a search, (probably using the wrong keywords) and can't find it. If anyone has written a FAQ about it or knows the thread, could you please post itThanks,JohnBTW, I'm using a 600D and SS4.0CP Quote Link to comment Share on other sites More sharing options...
raintheory Posted July 25, 2006 Report Share Posted July 25, 2006 (edited) Here you go:[attachmentid=1905]Under "Tools/Options/Transfer" - Click on "Hi-MD" then "Transfer Settings" to set the bitrate to whatever you'd like.Or you can simply click on this little button when in the transfer screen of SonicStage:[attachmentid=1908]EDIT: Welcome to the forums BTW. Edited July 25, 2006 by raintheory Quote Link to comment Share on other sites More sharing options...
Richard Posted July 25, 2006 Report Share Posted July 25, 2006 As Raintheory says or if ripping from CD use these options:[attachmentid=1907]Then make sure you transfer "as is" to avoid transcoding. (NB: only 192 & 352 will work with Hi-MD in addition to the original 48/64/132/256/PCM rates) * Thread moved to Software Discussion Quote Link to comment Share on other sites More sharing options...
