dragonheartsolo Posted August 4, 2006 Report Share Posted August 4, 2006 Can anyone please help. Have been using Sonic Stage for few year now, then i upgrade to 4.0 and now i get ERROR CODE 00005e30 in SONIC STAGE 00000908-645. Then the prog closes. Please anyone b4 my pc goes out the window. Thanks all. Quote Link to comment Share on other sites More sharing options...
dogville Posted August 4, 2006 Report Share Posted August 4, 2006 Can anyone please help. Have been using Sonic Stage for few year now, then i upgrade to 4.0 and now i get ERROR CODE 00005e30 in SONIC STAGE 00000908-645. Then the prog closes. Please anyone b4 my pc goes out the window. Thanks all.Something similar happened to me, but after updating my nvidia graphics card, it seems the problem is not so serious. It closes from time to time but not as often as before updating it.regards Quote Link to comment Share on other sites More sharing options...
Sony_Fan Posted August 7, 2006 Report Share Posted August 7, 2006 Can anyone please help. Have been using Sonic Stage for few year now, then i upgrade to 4.0 and now i get ERROR CODE 00005e30 in SONIC STAGE 00000908-645. Then the prog closes. Please anyone b4 my pc goes out the window. Thanks all.If you have Windows XP, use the System Restore and go back to when you had the previous version of SonicStage. If you tell us your computer specs, that would help others in helping you. Quote Link to comment Share on other sites More sharing options...
dogville Posted August 8, 2006 Report Share Posted August 8, 2006 (edited) If you have Windows XP, use the System Restore and go back to when you had the previous version of SonicStage. If you tell us your computer specs, that would help others in helping you.Thanks Chris, but precisely, it is due to disabling system restore that it seems to work okay by now.thanks motherboard: ASUS A8N SLI PremiumGraphics: Nvidia geforce 6600 gt SLIProcessor: Athlon AMD 3.2If you need further information, let me know. Edited August 8, 2006 by dogville Quote Link to comment Share on other sites More sharing options...
dogville Posted August 8, 2006 Report Share Posted August 8, 2006 (edited) Thanks Chris, but precisely, it is due to disabling system restore that it seems to work okay by now.thanks motherboard: ASUS A8N SLI PremiumGraphics: Nvidia geforce 6600 gt SLIProcessor: Athlon AMD 3.2If you need further information, let me know.Just an illusion By the way, I guess I have mixed my post with Dragonheart's Sorry Edited August 8, 2006 by dogville Quote Link to comment Share on other sites More sharing options...
