Hatebreed Posted August 9, 2006 Report Share Posted August 9, 2006 Hi, (to moderators..not sure where i shouldve posted this so if u want to move it to wherever it goes if its not here ....)I had a MH600D and i was just wondering how u get the player to suffle through ALL the songs on the disc?? Is their a way? I know that you can shuffle through 'group's but i wish there was a way to make it shuffle through ALL the groups on my DISC so i had alot of variety. Does anyone know how to do this? It'd be greatly appreciated Btw i used to record in hi-sp and low-sp but it updated (sonicstage) does anyone know what the equivalent of that is? 64bit or 192bit or? .....Thanx for your guys time. I dont know if i could shuffle the whole disc through 'bookmarks' cuase i dont know exactly how to use that feature yet.Thanx all Quote Link to comment Share on other sites More sharing options...
The Low Volta Posted August 9, 2006 Report Share Posted August 9, 2006 - if you set the playback mode to normal (instead of group play) you should actually shuffle through all tracks- the update of SS just gave us extra bitrates, some we can use with HiMD, some we can't:the old ones HiSP (256bkps) and HiLP (64 kbps) and PCM (full CD quality at 1411kbps) are still there, as are the older NetMD things: LP2 (132kbps) and fake SP (292kbps but at the qualiy of LP2 or even slightly lower)I don't really know what new ones work with HiMD and I'm not near my PC (typing this on a mac ), so I can't check, but I do know that 192kbps and 352kbps do work with all HiMD'sPS: all this can be found in a.) the NH600D's user manual (older bitrates and shuffle play); b.) SS-help (newer bitrates) and c.) all over this forum (all issues and the NH600D's user manual as well)... so perhaps search a bit before opening a new thread Quote Link to comment Share on other sites More sharing options...
greenmachine Posted August 9, 2006 Report Share Posted August 9, 2006 (edited) About the modes:Hi-SP = 256kbpsHi-LP = 64kbps (4x smaller files, but potentially lower fidelity)Never heard of low-sp before.About the shuffle issue: Pess the navi/menu button for less than one second and select normal instead of group. It will shoffle through the whole disc, ignoring groups completely.edit: volta was faster Edited August 9, 2006 by greenmachine Quote Link to comment Share on other sites More sharing options...
