SonicStage... DOES NOT WORK!
nightpred
Windows XP Home SP2
AMD Athlon xp 2500+
Gigabyte mother board
512ram
ATI Radeon 9800XT, driver up to date.
what in the hell is wrong with sonicstage???
the program does not work anyway i have tried. I have seen suggested ideas on here and alot of them make sense, but none work. Is there really a solution for this problem with the Omgj....exe not working? Should i take this up with the company? if someone has found a solution, it would be greatly welcomed onto my post :D If there are ideas someone may have that i havnt tried...
-changed display driver version countless times.
-instaled many versions of sonicstage, none work. all the samething.
-used some of the downloads offered in the downloads section, nothing worked.
I'm sorry to possibly repeat this post but i think this needs to be figured out, this is a major problem which needs to be fixed one way or another.
p.s. I will also send an email to sony explaining my situation, and wtf there going to do about it.
You HAVE to be more specific, ehat does it do or not do. What version are you using, what MD unit do you have? Are you trying to upload with a non Hi-MD unit? Are you trying to "Drag and Drop"?
There are many of us here who have no problems with SS.
If you go through the forum there may possibly be answers to your dilemna, try PM'ing one of the mods with a less inflamatoring attitude, and work with us.
Good luck,
Bob
Hi-MD Walkman MZ-RH910 is what im using.
I have tried several version of sonicstage and none work... All give the same error when loading the UI.
i tried the full installing offered on the website here, the 3.4. but the same error occured.
Sorry how i acted on my last post, this is really taking its toll on me, very bugging. like an ich you can't scratch.
Edited by nightpred
sigh.. wasnt the theme or skin or anything else. i uninstalled anything to do with transforming my windows, but it showed no difference. O well, I figured i may have to reformat. I tryed it on another computer in my household using winxp home and it worked fine so yeah.. either i reformat this or use the other as my data base for music.... I'll take the format route :D Wish me luck!
P.S. Thankyou for all suggested ideas.
