Trying to use a mic?!?!
Beyer66
hey, i just joined the forum, i hope some people here can give me some tips on usinig my net-md recorder.i'm trying to record live music with it. i just bought it from ebay a month or two ago, its a sony Net MD MZ-N510CK, which doesn't have a mic-in port, but my buddy had one once and he said you can use the line in with a powered mic. i borowed his sony powered mic, and it works, but i have to set the line level for recording all the way to 30 and the final recording comes out at a low volume. of course i tried everything like checking the batteries, etc..
i even contacted customer service via email with sony, and they advised me that the model # on the mic i'm using is not compatible with my MD. i asked which mic IScompatible, and they didnt really have an answer. i see alot of independent companies on the web selling stereo mics with battery boxes in-line, which look cool because you can hide the two small mics under the brim of your hat or something if you want to bootleg a concert. anyway, has anybody used one of these mics? http://cgi.ebay.com/ws/eBayISAPI.dll?ViewI...A%3AIT&rd=1
its 80 bucks and if i spend that much and it doesnt work that will suck. i also have been considering getting a new hi-md unit. i found some good prices on them, and i know they have mic-in plugs.
any ideas? should i get a better unit???
The only way you will get a mic to work with your unit is with a pre-amp, you would to better to try to plug into the mixing board line-out. That is not possible a lot of the time, so your next real choice is getting a unit with a mic input. a 700 or 800 can be got relatively cheaply, but if you can spare the dough, get an RH1, you will like it.
Good luck,
Bob
With amplified music you can go Mic-Battery module--Line-in. That's how I do nearly all my concert recordings.
These are the mics I use, about the size of Jelly Baby jellybeans:
http://www.soundprofessionals.com/cgi-bin/gold/item/SP-BMC-2
and this is the battery module, about the size of a keychain remote:
http://www.microphonemadness.com/products/mmcbmminminc.htm
That's a 9V battery module, stronger than your 1.5 volt AA and way smaller.
Very stealthy and hi-fi.
They're not the only choices by any means, but if you're recording music with any bass in it, look for a frequency response of 20-20,000 Hz, which your Sony doesn't have. (The ECM-MS907 is 100-15,000 Hz.) Before you buy Giant Squid, which does advertise 20-20,000 Hz, listen to the sound samples on their website. They sound awful to me--possibly because they're using bass roll-off without mentioning it, but there's no bottom to the recordings (check the B-52's or the Blue Notes) and the vocals are hugely exaggerated.
Yes, you should get a Hi-MD unit like the MZ-NH700 ($150 at http://www.minidiscaccess.com), not so much for the mic jack (though it's excellent for interviews) but because you'll be able to upload your recordings to a PC. (If you have a Mac, save up for a while and go for the MZ-RH1.) However, if you are recording amplified music you'll probably want to get a battery module and go through line-in anyway, because loud music often overloads the built-in mic preamp.
Edited by A440
you said i should get the hi-md JUST so i can upload my tunes to a PC??
i can do that with my current unit, or any minidisc recorder cant i?
i would think the major advantage of the hi-md format is the 40 hour discs, and the ability to use it as a additional computer drive if needed.
thanks for the advice on the mic, though. i may consider one of those mics, because even if i switch to a nicer recorder eventually, i can still use this mic.
NetMD units like yours can download songs from the computer faster than realtime, but it's only one-way. You can't upload live recordings you have made--only record them out of the headphone jack.
Hi-MD finally (and way too late) allows direct, fairly fast digital uploading. Only one model of Hi-MD will upload older recordings that weren't made on a Hi-MD unit--that's the RH1.
