c864fd5d Posted September 25, 2006 Report Share Posted September 25, 2006 I want to buy Rh1,but seem like the internal battery will not last very long.And if I use it to record,it can only have eight hours at 256 kbps,then need to recharge again.In this inconveniece ,I am difficult to decide on to buy it or not buy it.If there an external battery pack selling ?But searching the web I have not find one. Quote Link to comment Share on other sites More sharing options...
smkranz Posted September 26, 2006 Report Share Posted September 26, 2006 I want to buy Rh1,but seem like the internal battery will not last very long.And if I use it to record,it can only have eight hours at 256 kbps,then need to recharge again.In this inconveniece ,I am difficult to decide on to buy it or not buy it.If there an external battery pack selling ?But searching the web I have not find one.There are several external battery packs which will power or re-charge the RH1. Please review this thread:http://forums.minidisc.org/index.php?showtopic=16982 Quote Link to comment Share on other sites More sharing options...
c864fd5d Posted September 26, 2006 Author Report Share Posted September 26, 2006 (edited) Then I will not worry when the internal battery not work ,I have to paid much money to repair.Thanks for your reply. Edited September 27, 2006 by yst Quote Link to comment Share on other sites More sharing options...
Sparda Posted September 27, 2006 Report Share Posted September 27, 2006 You do know that it is easily removeable right? You can buy another LIP-4WM and cycle between them. Once the juice is drained you just swap it out for your spare, easily done in seconds, only concern is the price of the rechargeable battery. Quote Link to comment Share on other sites More sharing options...
c864fd5d Posted September 27, 2006 Author Report Share Posted September 27, 2006 I do not know anything about mechanics?Then I think I cannot able to replace myself(without damaging the player)THerefore I think external battery pack can do this purpose,when the internal battery die.I also wonder do I need extra budget to buy a sony mic when recording in RH1?Does the internal mic have enough quality,will it pick up internal drive voice like some HD player?If it is enough ,I rather not bother to buy a mic. Quote Link to comment Share on other sites More sharing options...
raintheory Posted September 27, 2006 Report Share Posted September 27, 2006 (edited) The supplied battery is meant to be replaceable. It's just as easy as replacing any standard battery, it is not built into the recorder in any way (no need to disassemble the unit or anything like that).There is no built-in mic, you will need to purchase an external one. The member greenmachine here in the forums makes great affordable mics - http://forums.minidisc.org/index.php?showtopic=14388 Edited September 27, 2006 by raintheory Quote Link to comment Share on other sites More sharing options...
Sparda Posted September 28, 2006 Report Share Posted September 28, 2006 (edited) The rechargeable battery is meant to be taken out, you can swap out an rh1 battery faster than you can on your tv remote. Thats how easy it is, no mechanics required.To prove how easy it is, i can take it out and put it back in in about 1.5 seconds. Edited September 28, 2006 by Sparda Quote Link to comment Share on other sites More sharing options...
