INSGADGET Posted September 27, 2006 Report Share Posted September 27, 2006 Hi! I work in Turkhis Tv channel live music. I did a lot of records by HiMD player, but all in my records avilable copy protection so I can't play and convert. What I can do? How I crack copy protection? Thanks. Quote Link to comment Share on other sites More sharing options...
Richard Posted September 27, 2006 Report Share Posted September 27, 2006 You may want to try this for starters:http://forums.minidisc.org/index.php?showtopic=16088 Quote Link to comment Share on other sites More sharing options...
INSGADGET Posted September 27, 2006 Author Report Share Posted September 27, 2006 Thanks but its not yet for meI copied all my .oma file in sonic stage/packages/HiMD to dvd. Than I format my pc delete all data but I setup pc and installed sonic stage again copied dvd to in sonic stage/packages/HiMD. Now all my oma file copy protect so don't use any file.I use marchants all rendered programs but not convert it. Never play never convert it offfff Quote Link to comment Share on other sites More sharing options...
A440 Posted September 28, 2006 Report Share Posted September 28, 2006 You are probably out of luck. The procedure you were supposed to use was to run the Backup Tool under C:Programs/SonicStage, not to just copy the files. Sony was afraid that you would use your minidisc for music piracy if you could simply make copies of your files. So the files you copied are coded to play only on your old installation of SonicStage, which you no longer have because you formatted your PC. Save the files in hopes that someday Sony allows its encryption to be broken, but currently there is no crack and those files are useless. With new files, either run the Backup Tool or use the File Conversion Tool as explained here. http://forums.minidisc.org/index.php?showtopic=16088 Quote Link to comment Share on other sites More sharing options...
