Connecting the Sony MZ-R55 to Mac - is it possible ?
Revilo
I believe the only way would be if you had a soundcard with an optical out which you could connect to the optical in on the R55. In this case you would need an optical cable probably of the type Toslink to Optical-Mini connection.
Alternatively it could be possible to connect the headphone out of the soundcard to the line-in of the R55, but the quality would ceratainly not be as good.
