MZ-R710 remote cut in half
Joy
Oh no! :blink: Check eBay or minidisc online retailers, that's all I can think of. Maybe you could find some other remote that would work with your minidisc unit. I suppose you could try to fix it if you're handy with wire strippers and some electrical tape, but...............
Good luck.
Good luck.
or glue it back together......
Did you mean N710? I couldn't find "R710" anywhere. It's probably not worth getting the remote fixed. eBay has a lot of new remotes for sale. RM-MC33EL, -38EL, -11EL are just a few Sony remotes that would work with your N710 and can be found for around US$20. The 40ELK is the daddy of remotes, but it's more expensive. Good luck!
What exactly got "cut in half"? The remote itself :eek: or just the cord? If it's just the cord it's not that hard to repair. If the remote itself is somehow craked/broken then that's the end of it pretty much, lol.
Either way as ppl said above, you could just buy a replacement and it shouldn't cost too much...
