c864fd5d Posted October 11, 2006 Report Share Posted October 11, 2006 (edited) Hi:I want to buy a mono mic,but not sure if Rh1 can use with this,does the 1-gb disk record with mono mic.If I mostly record lecture,(very rarely will record mucical ceremony,but this occassion really rare),then do you think the mono mic will affect the quality,I am far away from the voice source,and always there is two person I have to record:professor and a translator.just wonder would stereo is better(but more expansive also)I just want to make sure mono mic is compatible with Rh1 before buying it.Very thanks Edited October 11, 2006 by yst Quote Link to comment Share on other sites More sharing options...
sector001 Posted October 11, 2006 Report Share Posted October 11, 2006 (edited) yst said: Hi:I want to buy a mono mic,but not sure if Rh1 can use with this,does the 1-gb disk record with mono mic.If I mostly record lecture,(very rarely will record mucical ceremony,but this occassion really rare),then do you think the mono mic will affect the quality,I am far away from the voice source,and always there is two person I have to record:professor and a translator.just wonder would stereo is better(but more expansive also)I just want to make sure mono mic is compatible with Rh1 before buying it.Very thankscan i ask u why u want a mono mic? i dont see why the RH1 wont be compatible with the mono mics. Edited October 11, 2006 by sector001 Quote Link to comment Share on other sites More sharing options...
greenmachine Posted October 11, 2006 Report Share Posted October 11, 2006 A mono mic with a mono plug will give a signal only on the left channel, silence on the other. A mono mic with a stereo plug will send the signal to both channels.Mono mics are a good idea for close miking [mic close to the source/speaker] but a bad idea for far miking in echoey rooms. The room information [reverberations, echoes] and the main source [speaker] will get mixed to a single channel, result in a muddy mix and make it hard for the brain to decode [separate source from room information]. If you use a stereo mic and set it up like the human hearing apparatus [distance of approx. 6-8 inches], the result will appear much clearer, more lively, requires less concentration, particularly when listening with headphones. Quote Link to comment Share on other sites More sharing options...
c864fd5d Posted October 11, 2006 Author Report Share Posted October 11, 2006 (edited) I really thanks for all the reply and kindful help.I buy mono because the mic if in stereo need extra $90,it seems to me is a large amount of money.This mic:mt830-spI am not knowing whether it is best ,but it seems the noise ratio is high:70 dB,I suppose it can give me less noisy recording than other,but it said mono only$95,stereo add $90! The spec is hereSpecification Quote Designed for use with equipment having microphone inputs that provide 'plug-in-power', or with one of our battery modules available here for mono mics and here for stereo mics. Stereo pairs are joined at the connector.But I do not know do I still need a stereo adaptor if buying mono?And can this mic used with Rh1 without battery or preamp?Directly plug in the mic in jack of RH1,I does not have any md player,so I just guess it will work.Would this mic too sensitive and make clipping easily(but I use record lecture only,not loud sound anyway), I also assume it has more quiet and less noise,just I guess it because the provided spec!But I think careful research is necessary,therefore posted here before buying it.I also have a question,If I choose a mic for RH1,some mic has high and low sensitive option,then which type should I choose would be suitable?If with preamp should I choose High Sen. and if WITHOUT preamp should I choose Low Sen?Thanks for the patience for reading my post. Edited October 12, 2006 by yst Quote Link to comment Share on other sites More sharing options...
sector001 Posted October 11, 2006 Report Share Posted October 11, 2006 yst said: I really thanks for all the reply and kindful help.I buy mono because the mic if in stereo need extra $90,it seems to me is a large amount of money.This mic:mt830-spI am not knowing whether it is best ,but it seems the noise ratio is high:70 dB,I suppose it can give me less noisy recording than other,but it said mono only$95,stereo add $90! The spec is hereSpecificationBut I do not know do I still need a stereo adaptor if buying mono?And can this mic used with Rh1 without battery or preamp?Directly plug in the mic in jack of RH1,I does not have any md player,so I just guess it will work.Would this mic too sensitive and make clipping easily(but I use record lecture only,not loud sound anyway), I also assume it has more quiet and less noise,just I guess it because the provided spec!But I think careful research is necessary,therefore posted here before buying it.Thanks for the patience for reading my post. yes, the RH1 has a mic in, u can just plug the mic and it should work. Quote Link to comment Share on other sites More sharing options...
