orange Posted October 20, 2006 Report Share Posted October 20, 2006 I know that this is the type of small question that infuriates people, and seems a waste of forum space. But the truth is that I have very little use (as present) for most of the MZ-RH1's functionality and, in addition, I'm remote- and instruction book phobic. So, the question is, could someone please give me an idiots step-by-step guide to changing playback speed via the remote? Quote Link to comment Share on other sites More sharing options...
sector001 Posted October 20, 2006 Report Share Posted October 20, 2006 I know that this is the type of small question that infuriates people, and seems a waste of forum space. But the truth is that I have very little use (as present) for most of the MZ-RH1's functionality and, in addition, I'm remote- and instruction book phobic. So, the question is, could someone please give me an idiots step-by-step guide to changing playback speed via the remote?i dont think you can change the playback speed on the remote..... Quote Link to comment Share on other sites More sharing options...
paularmenores Posted October 21, 2006 Report Share Posted October 21, 2006 Just hold down the display button on the remote. A menu will appear which you can scroll through using the fast-foward and rewind buttons until you get to 'SpeedCtrl'. Hit the play button, then you can adjust the speed using fast-foward and rewind again. Quote Link to comment Share on other sites More sharing options...
orange Posted October 21, 2006 Author Report Share Posted October 21, 2006 pa5005 - thank you! I think I'm instruction-book myopic or something. After following your simple directions with easy success, I checked the book again, only to realise that I hadn't been reading it right. Thanks for your patience! Quote Link to comment Share on other sites More sharing options...
sector001 Posted October 21, 2006 Report Share Posted October 21, 2006 pa5005 - thank you! I think I'm instruction-book myopic or something. After following your simple directions with easy success, I checked the book again, only to realise that I hadn't been reading it right. Thanks for your patience!i haven't read the manual either..... Quote Link to comment Share on other sites More sharing options...
orange Posted October 21, 2006 Author Report Share Posted October 21, 2006 i haven't read the manual either..... Quote Link to comment Share on other sites More sharing options...
Sparda Posted October 25, 2006 Report Share Posted October 25, 2006 i haven't read the manual either.....You mean to say you have never accessed the menu on your remote? I'm sure you would come across the SpeedCtrl if you entered the menu just once. Quote Link to comment Share on other sites More sharing options...
sector001 Posted October 25, 2006 Report Share Posted October 25, 2006 You mean to say you have never accessed the menu on your remote? I'm sure you would come across the SpeedCtrl if you entered the menu just once.i just recently got the rh1 and haven't fully explored it's capabilities. Quote Link to comment Share on other sites More sharing options...
Sparda Posted October 26, 2006 Report Share Posted October 26, 2006 I see..... well you should get going! It's a great unit even with some quirks here and there. Quote Link to comment Share on other sites More sharing options...
