twodogs Posted October 23, 2006 Report Share Posted October 23, 2006 I've got 2 batteries for my NH1, and one of them refuses to charge. Doesn't matter if it's plugged into the computer or the charger, it just does nothing....can't even get the player to fire up (when play is pressed on the remote, it did say "low battery").any ideas how to get it to charge? Quote Link to comment Share on other sites More sharing options...
sector001 Posted October 23, 2006 Report Share Posted October 23, 2006 twodogs said: I've got 2 batteries for my NH1, and one of them refuses to charge. Doesn't matter if it's plugged into the computer or the charger, it just does nothing....can't even get the player to fire up (when play is pressed on the remote, it did say "low battery").any ideas how to get it to charge?perhaps the battery is just dead, how long did u have the battery? Quote Link to comment Share on other sites More sharing options...
Sparda Posted October 24, 2006 Report Share Posted October 24, 2006 I think it is dead too, try cleaning the conenctions on the battery. Quote Link to comment Share on other sites More sharing options...
twodogs Posted October 25, 2006 Author Report Share Posted October 25, 2006 I think it's probably 18 months old...you'd think that it would charge abit, just not hold the charge if it was dead. I'll clean the terminals and try again. Quote Link to comment Share on other sites More sharing options...
greenmachine Posted October 25, 2006 Report Share Posted October 25, 2006 remove the battery from the main unit when not in use for longer periods to avoid deep discharge and its effects Quote Link to comment Share on other sites More sharing options...
Sparda Posted October 27, 2006 Report Share Posted October 27, 2006 18 months? I would say its time to retire. Quote Link to comment Share on other sites More sharing options...
