spy1983 Posted October 24, 2006 Report Share Posted October 24, 2006 HiI have a MZ-NH900 md recorder and bought a new sennheiser cx300 earphones. I was using sony mdr-e818lp earphones before. I couldnt get a better performance form cx300's, in fact they are much better than the sony ones. Cx300's have lots of bass some i had to lower the bass frequencies from the equaliser. I couldnt get a live, great sound from cx300 earphones. The sound is not live when i raise the treble. It sound like a poor earphones.Can you please help me about equaliser settings? Or does anyone use the same combination? (MZ-NH900 AND CX300) Which setting should i use or do you use?ThanksRegards Quote Link to comment Share on other sites More sharing options...
sector001 Posted October 24, 2006 Report Share Posted October 24, 2006 HiI have a MZ-NH900 md recorder and bought a new sennheiser cx300 earphones. I was using sony mdr-e818lp earphones before. I couldnt get a better performance form cx300's, in fact they are much better than the sony ones. Cx300's have lots of bass some i had to lower the bass frequencies from the equaliser. I couldnt get a live, great sound from cx300 earphones. The sound is not live when i raise the treble. It sound like a poor earphones.Can you please help me about equaliser settings? Or does anyone use the same combination? (MZ-NH900 AND CX300) Which setting should i use or do you use?ThanksRegardsequalizer settings are very subjective, my suggestion is to experiment with them. what sounds good to some may not sound good to you. Quote Link to comment Share on other sites More sharing options...
nickel Posted October 25, 2006 Report Share Posted October 25, 2006 e what sounds good to some may not sound good to you.That's true! This is the only way to adjust the sound! Quote Link to comment Share on other sites More sharing options...
