Musashinden Posted December 4, 2006 Report Share Posted December 4, 2006 I am thinking of getting a new minidisc player finally and I remember posting in the forums here last year, about November about a particular problem I had regarding the recording function on the minidisc player I had/have. The recording stopped because of the faulty ribbon cable that connects to the motherboard of the player had broken/snapped due to stress(?). I am thinking of purchasing an MZ-RH1 and my BIGGEST question is: does the MZ-RH1 suffer from the SAME problem? Does it have the SAME ribbon cable setup/layout as the Player I have? (that, as I type this, sits in a dark and cold compartment with all the original parts....) If so, then chances are, it will suffer the SAME exact fate over time as the player I currently have and I really don't wish to waste money in that fashion, seeing as minidisc players are potentially, to me, the best portable audio players out there . Thanks for any and all input. Quote Link to comment Share on other sites More sharing options...
Hungerdunger Posted December 4, 2006 Report Share Posted December 4, 2006 You forgot to mention that your machine was an MZ-N1.I don't own one so I'm not sure exactly what you're talking about with regard to the ribbon cable, but I can see a small ribbon cable when I look inside my RH1.Having said that, I look at these forums quite regularly and can't recall any recent posts about the problem you had.I guess that at the end of the day you'll have to decide for yourself whether it is worth the risk. Or you just buy an Ipod and hope it isn't one of those whose battery fails just outside the warranty period. Quote Link to comment Share on other sites More sharing options...
Musashinden Posted December 5, 2006 Author Report Share Posted December 5, 2006 Actually, the topic is here:http://forums.minidisc.org/index.php?act=S...ost&p=73522As you can see, i wasn't the only one . They weren't recent posts, but i thought it was something to consider before buying a new MD player. Quote Link to comment Share on other sites More sharing options...
Roamer Posted December 6, 2006 Report Share Posted December 6, 2006 All devices with some mechanical parts will eventually fail after some time (and even flash memory can fail). The MZ-N1 was actually notorious for this failure.The MZ-RH1 is less than one year old, so hopefully not too many people have trouble with the unit, but time will tell ... Quote Link to comment Share on other sites More sharing options...
Sparda Posted December 15, 2006 Report Share Posted December 15, 2006 I wouldn't let this small problem affect me decision on buying a new DAP. Take the iPod for example, you risk the harddrive failing on you, you also risk being unable to replace the rechargeable Li-Ion battery. Flash based players suffer from memory loss, as you use it more and more the capacity slowly decreases for no apparent reason. I guess what I'm saying is, if you don't go with MD you will also encounter a bunch of problems with other solutions. But it's your choice, since I personally wouldn't like it if my ribbon cable broke too. Quote Link to comment Share on other sites More sharing options...
jaylen Posted December 15, 2006 Report Share Posted December 15, 2006 Actually, the topic is here:http://forums.minidisc.org/index.php?act=S...ost&p=73522As you can see, i wasn't the only one . They weren't recent posts, but i thought it was something to consider before buying a new MD player.I had an N1 with that problem. It hasn't stopped me from buying more MD units. But, it did leave me a little paranoid with my current recorders so that's why I've also purchased player-only models to hopefully reduce wear and tear on those recorders. On the other hand, there are still some N1 users out there whose units still work 100%.If you get the RH1 and still worry about it crashing like your N1, you can always get a player-only unit (or a lower-costing unit) later on to compliment it and share the workload. Good luck! Quote Link to comment Share on other sites More sharing options...
Musashinden Posted April 27, 2007 Author Report Share Posted April 27, 2007 Strange lol, after all these months, my RH1 is finally arriving soon and i hope this problem wont happen again, but this time, i'll take a look into the warranty lol. Thanks for all the input people, though it was sometime ago lol. Quote Link to comment Share on other sites More sharing options...
Superbaldguy Posted April 28, 2007 Report Share Posted April 28, 2007 I am guessing Sony learned from the N1 follies about making the ribbon connector more robust; you don't hear much about that happening with later units. Quote Link to comment Share on other sites More sharing options...
