rich.jenn Posted December 7, 2006 Report Share Posted December 7, 2006 HiI have an MZ-N710 which I'm delighted with as a player.Just trying to start using Net MD.I have lost the Sonic Stage 1.5 CD that came with the unit.Downloaded versio n4.2 from Sony website.Can only get that software to offer me options to burn CDs - I want to "checkout" music to my MZ-N710.Am I doing something obviously stupid, or is this the wrong version of Sonic Stage for that task?Sony, as always, don't make it easy, or reply to mail.Thanks v muchRichjenn13 Quote Link to comment Share on other sites More sharing options...
Syrius Posted December 7, 2006 Report Share Posted December 7, 2006 First, there is no need to check out any music. If you have imported tracks to your library, make sure your player is connected, then look for the "transfer" option. That should allow you to move tracks to your player, without the need to check them in ever. Quote Link to comment Share on other sites More sharing options...
bobt Posted December 7, 2006 Report Share Posted December 7, 2006 If it's CD's you want to get to your MD use Simple Burner, works the best,If not just yse SS to transfer the dongsGood luckBob Quote Link to comment Share on other sites More sharing options...
rich.jenn Posted December 9, 2006 Author Report Share Posted December 9, 2006 If it's CD's you want to get to your MD use Simple Burner, works the best,If not just yse SS to transfer the dongsGood luckBobThanks Bob.PS Love the Citroen - are you running it out there?I'm having a love /hate relastionship with a BX TZD - not the same class as a DS of course, but similarly loveable/drive you mad!CheersRichardFirst, there is no need to check out any music. If you have imported tracks to your library, make sure your player is connected, then look for the "transfer" option. That should allow you to move tracks to your player, without the need to check them in ever.Thanks Syrius - will give it a go!CheersRichard Quote Link to comment Share on other sites More sharing options...
