himd_user Posted December 22, 2006 Report Share Posted December 22, 2006 (edited) Check this out.Record some audio on your HiMD deck.Import it into SONICSTAGE on your PC/MS-Windows machine.Save this file as TEST.OMA.Now take your MACBOOK PRO running OSX.Install "Parallels". This allows you to run MS-Windows natively, as a "window" inside OSX. (Cool by itself)Mirror your PC/MS-Windows hard drive into Parallels-OSX using the Parallels "Transporter" network transfer program.Now "BOOT" your MS-Windows hard drive on your MACBOOK PRO. Your MS-Windows is now running inside a window on OSX (where it deserves to be caged).This MS-Windows-on-OSX has Sonicstage. Run it.See your TEST.OMA track.PLAY YOUR OMA TRACK. Hear the track on the MACBOOK PRO's speakers.HiMD Audio recordings transferred to the PC machine play on the Macbook Pro.HELL YES.DRM for self-recorded tracks has no place here!More items of note:Running Marcnet HiMD Renderer under Windows2000 inside MAC OSX+Parallels can convert the track from OMA to MP3.Both the OMA and the MP3 can be played under Windows Media Player running inside OSX+Parallels.Drag & Drop the MP3 file from Parallels window -> OSX desktop, double-click, the file is now playing in iTUNES!I will never buy another microsoft product again. Edited December 22, 2006 by himd_user Quote Link to comment Share on other sites More sharing options...
Richard Posted December 22, 2006 Report Share Posted December 22, 2006 * Moved to Software Discussion section Quote Link to comment Share on other sites More sharing options...
