David Leth Williams Posted February 3, 2006 Report Share Posted February 3, 2006 Hi.I recieved my new nw-a3000b today. I get home, excited to try the thing.I put the connect player cd in the cd drive, and start the installation. All is fine till now.Then comes my problem:As you can see, I cannot see the radio buttons, and therefor I cannot continue from there.It was the same on the opening screen, and the screen where you choose location.Has anyone experienced anything similar?Help will be greatly appreciated!Cheers. Quote Link to comment Share on other sites More sharing options...
Christopher Posted February 3, 2006 Report Share Posted February 3, 2006 What is your screen resolution (800x600, etc)? Also, have you tried hitting the tab key? Quote Link to comment Share on other sites More sharing options...
David Leth Williams Posted February 3, 2006 Author Report Share Posted February 3, 2006 My resolution is 1152x864, i also tried switching to 12**x***.I tried tab to, doesn't seem to work. Quote Link to comment Share on other sites More sharing options...
Richard Posted February 3, 2006 Report Share Posted February 3, 2006 (edited) On the screenshot you have attached it looks like the back button is highlighted.If you press shift-tab to go to the previous item does the "next" button activate? Or try shift-tab, then use the cursors to go up and down (hoping to toggle between yes/no for the acceptance). Also scroll down to the end of the agreement - does anything change? Edited February 3, 2006 by richyhu Quote Link to comment Share on other sites More sharing options...
David Leth Williams Posted February 3, 2006 Author Report Share Posted February 3, 2006 I also tried scrolling to the bottom, nothing changed.Its like the buttons aren't there. When you are in the textfield, and press tab, it goes straigh to the "tilbage"(back) button. Then to "annuller"(cancel), and back to the text field. Quote Link to comment Share on other sites More sharing options...
David Leth Williams Posted February 3, 2006 Author Report Share Posted February 3, 2006 (edited) I gave up, and downloaded SonicStage 3.4 instead. I hope it works out.Thanks for your help. Edited February 3, 2006 by David Leth Williams Quote Link to comment Share on other sites More sharing options...
Guest Stuge Posted February 4, 2006 Report Share Posted February 4, 2006 David Leth Williams,I know you have given up but tell us what is the size of your moniter..Also have you installed Direct X9.c????You can check it by typing "Dxdiag" in RUN Quote Link to comment Share on other sites More sharing options...
David Leth Williams Posted February 4, 2006 Author Report Share Posted February 4, 2006 Actually i managed to install Connect player now. I kept trying since apparently you had to, because it comes with some openMG drivers or something.On the screen, i had to press up/down, which i hadn't tried.I only pressed left/right - don't ask why. My monitor is 17", and i have DX 9.0c. Quote Link to comment Share on other sites More sharing options...
granbajo Posted February 5, 2006 Report Share Posted February 5, 2006 I too had this problem... BTW, you will get it as well when installing the upgrades... using tab and up and down arrows does the trick! It has nothing to do with the screen resoloution (I changed it to every single one my computer supported without luck). On the thread I started around Christmas, someone mentioned that he had also seen the problem and he thought it was caused by having firefox installed... I also have FF... do you? I am just curious to find out if this is really the cause of the problem. Quote Link to comment Share on other sites More sharing options...
Guest Stuge Posted February 5, 2006 Report Share Posted February 5, 2006 Updating the Microsoft explorer 6.0 might do the trick Quote Link to comment Share on other sites More sharing options...
David Leth Williams Posted February 5, 2006 Author Report Share Posted February 5, 2006 Granbajo: I have FF installed, and it is my default browser. Sounds plausible that, FF could be the cause. It just seems wierd that a browser could affect CP that much...Stuge: I have IE v6. Quote Link to comment Share on other sites More sharing options...
granbajo Posted February 5, 2006 Report Share Posted February 5, 2006 I also have IE 6... so it definitely doesn't fix it Quote Link to comment Share on other sites More sharing options...
Heman Posted February 7, 2006 Report Share Posted February 7, 2006 Please make English language as your system default (Control Panel>Regional Settings), and try again. Good lucks. It seems your language (Danish?) is using double-byte format (singe font width) as non-Latin characters. Other workaround is to change Display pixel in registry, too danger. Quote Link to comment Share on other sites More sharing options...
