Where can I buy a USB cable etc?
KevinB
The USB to Mini-B cable is very common. You can walk into BestBuy or the equivalent and get the cable there. Any generic USB to Mini-B cable should work just fine.
P.S. Many cameras uses this cable, maybe you already have one?
Thanks - I do have a USB cable for my Olympus camera, but the plug is just a shade too big to fit the minidisc. It wouldn't surprise me if Sony's plugs were extra small; just look at the 'size' of the screws holding it together and the tiny charger plug. But thanks anyway, I think a cheapo unit, with cable, from eBay may be the solution. Kevin
