chojin Posted March 1, 2007 Report Share Posted March 1, 2007 (edited) I've owned my MZ-NH700 for about a year and half now and it just doesn't seem to want to conserve its energy anymore. I'll charge it completely and have one battery bar on the screen missing after recording less that a minute of audio. I was using it to record quite a bit when i first got it but have just started trying to use it again and I'm having this problem. Any suggestions? If nothing can be done can somebody recommend something I can record with in stereo that will last longer than a year?ThanksEdit: Brand new Sony Ni-MH rechargeable batteries are drained as well. Edited March 1, 2007 by chojin Quote Link to comment Share on other sites More sharing options...
pata2001 Posted March 1, 2007 Report Share Posted March 1, 2007 You know, you can just buy some more AA batteries/rechargables. Quote Link to comment Share on other sites More sharing options...
chojin Posted March 1, 2007 Author Report Share Posted March 1, 2007 pata2001 said: You know, you can just buy some more AA batteries/rechargables.Hey... Yea, I actually did know that... I've tried replacing them. That's not the problem. Quote Link to comment Share on other sites More sharing options...
Sparda Posted March 1, 2007 Report Share Posted March 1, 2007 Would the NH700 happen to feature quickmode? If it does check to see if it is off. And if using new batteries don't fix the problem then I guess you need to start looking for your next one. Quote Link to comment Share on other sites More sharing options...
Sparky191 Posted March 1, 2007 Report Share Posted March 1, 2007 I bought my MZ-NH700 2nd hand a couple of years back. Still working fine. Your unit must be faulty. I've never seen anyone report that problem with a HiMD before. Quote Link to comment Share on other sites More sharing options...
Avrin Posted March 1, 2007 Report Share Posted March 1, 2007 (edited) Try cleaning battery contacts in the unit - they are definitely a bit dirty and oxidized after a year of use. Be very careful, not to damage or break anything! Also, clean the batteries themselves before inserting. Edited March 1, 2007 by Avrin Quote Link to comment Share on other sites More sharing options...
chojin Posted March 1, 2007 Author Report Share Posted March 1, 2007 Thanks guys. I got it working. Not only did I clean the contacts, which didn't look dirty, I also blasted some air through the open lid to get anything that might be causing a short off of the circuit. I also blasted a bit of air through all of the inputs just in case. Quote Link to comment Share on other sites More sharing options...
