Sonicstage Database problem(error 00005e36)
CrackBone
Has anybody solved this?
I have tried uninstalling sonicstage, deleting everything in my registry, using mdac repair....nothing works.
It keeps saying that it cannot find the database file and it has to be restored and after that it says it cant do even that. And then it tries to copy an empty database file and it says: "The files that are required to use the database file may not be located".
F@#K!!!
Help me out plz...this is the first time I have such a problem.
Have either of you tried reinstalling MDAC completely? This sometimes will work when the repair tool fails.
Indeed as Raintheory suggests I would try downloading and installing:
1/ MDAC 2.8 SP1 - from here http://www.microsoft.com/downloads/details...;displaylang=en
2/ Jet 4.0 SP8 from here: http://www.microsoft.com/downloads/details...;displaylang=en if you are using Windows XP or from here: http://www.microsoft.com/downloads/details...;displaylang=en if you are on Windows 2000.
