Track problem after importing into Sonic Stage
vpalem
Hello Friends,
My Hi-Md Is MZ-RH1. Before 2 months I purchased it.
The problem I face Is during recording a talk from mixer or amplifier is, it is getting recorded In So Many Tracks Max 280 Tracks.. Now Using The Sonic Stage I Can Transfer It In To P.C..
But I Want To Store It In Ipod..In Single Track..
Is There Is Any Way To Save These 280 Tracks In To Single Track.. So That It Looks Very Good In The Ipod.
I Would Appreciate U R Reply And Suggestion..
Thanks.
Starsnsky
You have two options:
1 - Remove the track-marks prior to uploading using the t.mark button (in play-pause, move to each track and press t.mark to remove the track mark).
2 - Highlight all of the tracks in SonicStage after uploading and use the "combine" feature under the edit menu. Be sure the tracks are in order before doing this.
Unfortunately the unit will automatically add track-marks when there is silence during a line-in recording. No way to disable this "feature".
On Method 2, don't combine all of them at once. You could, but it will take forever and I don't like to give SonicStage too many things to do in one command.
Combine, oh, 20 at a time if they're short. So do 1-20, then (1-20) plus 21-40, etc.
Just to repeat raintheory, make sure you are highlighting them in order. If you don't, you can't un-combine them easily.
