What in the world is the point of Groups on my HD3?
On MD I can completely understand groups but on an HDD DAP like the HD3, it seems very senseless and seems to make things harder for me...
For example if I don't want to use SS to import all my MP3s ('cause I only want to use some of them on the HD3 and I want to keep all the MP3s I've ripped from CDs separate from the ATRAC files I've ripped) things aren't so easy. Because then you can use MP3FM but that doesn't allow you to create group folders it seems. All you can do is transfer files.
Like here's an example... For some CDs I have a few tracks aren't on the CDs (e.g. I've gotten bonus tracks in MP3 format off the internet for some CDs). So I first copy the CD in ATRAC3plus in SS and then transfer to the player. Then I want to put the bonus tracks (which I only have in MP3) over to the player. So I figure okay the files will automatically go into the right album on the HD3 because its the same album name in the file tag.
Then it transfers and I'm like where are the files? Try in MP3FM and can't see where they've gone; try in SS and can't see them either. So try the player and there they are... So I finally figure out that the files did transfer but there are Group folders that go over onto the HD3 which are named according to the original album you transferred but are otherwise not linked to the arrangement of the files on the HD3. So the files I transferred went into a Group with another album name.
What I don't get is why did they bother with groups at all? It just makes more work for you because if you want to transfer MP3s you have to then go back into SS and place the files in the right group (so you know where to find them later as the group folders are named by album); and if you want to transfer other files that you don't have a group folder for you have to go into SS first, make the group and then go back to MP3FM and transfer the files? What kind of foolishness is that? I just don't get it?!?!? At first you think the group folders *are* the album folders but that isn't it at all. The HD3 just gets it's album arrangement info from the file tags and the groups are, well, senseless IMO.
Does anyone actually use groups? I don't get why you'd want to use them... I guess maybe for making a playlist or something?
MDX-400
5 answers to this question
