MD material won't transfer into SS
theblueraja
I had to reinstall Sonic Stage 4.3 since I reformatted my PC w/ a new HD. All was well... then for the first time I tried ripping from MD to the computer (in SS), some popup question came up, and I hit cancel by mistake, and now it won't let me rip anything from MD... when I click the left arrow button the right side flashes once, says "loading", then nothing happens, no transfer, no matter what my settings are (kb settings, or create .wav file, etc).
Here's the kicker; I've removed & reinstalled SS 4.3 TWICE, once the version that came with a new walkman, and once the direct download. And before the 2nd time I reinstalled, I deleted all the root Sony folders that I saw were still on my HD. Yet, when I reinstall, somehow it has STILL kept MY default kbps setting.... AND, still can't rip from MD anymore. :(
Help!!!
Edited by theblueraja
Help!!!
Hey Raja , uninstall SS then go into "Reg Edit " .You will have to do into the registry and delete any thing and everything related to Sony check ALL the files in the registry for stuff related to SS and SONY , it will be spread out . Then after all that reinstall SS but read everything before you click it .
THAT DID THE TRICK!!
Bless you :) and THANK YOU :)
And Sonic Stage is great, I just messed up. ;)
