MZ-N1 software
majeeko
Hi and welcome :) - you will need to use Sonic Stage which you can either download in it's version 4.0 incarnation via the full installer in our downloads and then upgrade to version 4.2 via Sony's support site which provides a web installer.
Or you can try and go for the full-blown 4.2 or 4.3 from one of the links provided in this thread: (if you do use one of those links also make sure you download the drivers for NetMD devices which will need to be installed first.)
http://forums.minidisc.org/index.php?showtopic=18671
