suzanneh Posted June 21, 2007 Report Share Posted June 21, 2007 I'm a new minidisc recorder owner (Mz-RH1) who now needs to choose a good one-point stereo mic. Has anyone compared an AudioTechnica-Pro24 to the Sony ECM-907 for sound quality and durability? Quote Link to comment Share on other sites More sharing options...
Antala Posted June 21, 2007 Report Share Posted June 21, 2007 Lovechild said: I'm a new minidisc recorder owner (Mz-RH1) who now needs to choose a good one-point stereo mic. Has anyone compared an AudioTechnica-Pro24 to the Sony ECM-907 for sound quality and durability?Like 2 months ago I was looking for a One-point Stereo Mic and after a lot of research I bought the Nady CM-2S. From what I read so far the At Pro 24 and Sony ECM-907 are both good choices but with a few more dlls you can get the Nady and its a better option than those Mics.One of the best options in the Market is the AT 822 but its a bit pricey compared to those mics. People that have the Sony ECM-907 say that it has great Stereo separation its also an Old Mic with nice reputation.I was in the same situation as you because I was going to buy the Sony ECM-907 or the At Pro 24 but in the end I bought the Nady CM-2S because I read owner comments and heared some samples and I knew it was the Mic I was looking for.So I reccomend you to Search the Forums and you'll see lots of topics with information regarding the Microphones you wanna get. Quote Link to comment Share on other sites More sharing options...
suzanneh Posted June 21, 2007 Author Report Share Posted June 21, 2007 Thanks Antala. I searched the forum earlier and didn't find the mic information I was looking for. Quote Link to comment Share on other sites More sharing options...
Strungup Posted June 21, 2007 Report Share Posted June 21, 2007 (edited) Lovechild said: Thanks Antala. I searched the forum earlier and didn't find the mic information I was looking for.I am an owner of the AT 822 and can testify to it , I practically dont use anything else on MD , it is worth the investment Audio Techica AT-822 one point Stereo , Freq Response 30 hz - 20 Khz selfpowered (AA Battery) http://www.audio-technica.com/cms/wired_mi...33dc/index.html Perfect companion to the RH1 Edited June 21, 2007 by Guitarfxr Quote Link to comment Share on other sites More sharing options...
suzanneh Posted June 22, 2007 Author Report Share Posted June 22, 2007 Thanks, GuitarFixer. Quote Link to comment Share on other sites More sharing options...
Andrej Posted June 22, 2007 Report Share Posted June 22, 2007 (edited) Guitarfxr said: Audio Techica AT-822 one point Stereo , Freq Response 30 hz - 20 Khz selfpowered (AA Battery) http://www.audio-technica.com/cms/wired_mi...33dc/index.html Perfect companion to the RH1I also have an AT (ATR25, powered with AA). Tried to use it with RH1 through LINE IN - nothing. The best results got from MIC IN with sensibility set to LOW (with HIGH it records talks in the neighbor flat!). How is AT-822 through LINE IN? I'm afraid I can demage MIC IN when using a AA-powered mic... silly?One more question - what is the best way to reduce static noise after recording? Or just to make lower rec level while session? Edited June 22, 2007 by Andrej Quote Link to comment Share on other sites More sharing options...
