Audio Technica ATR35S vs Sony ECM-DS70P
hsl13
Hi,
I currently use a Sony ECM-DS70P microphone connected to the mic-in on Hi-MD recorders RH910 and NH1. The music I record is loud and from what I have been reading on the forum, for live music it would be better to use a microphone connected to a battery box then connected to the line-in of the recorder. I want to avoid having to use a battery box so am looking at microphones that have there own battery power so I can connect it to directly to the line in. Problem is I do not want any thing as big as a sony ECM-MS907 microphone, it has to be small like the ECM-DS70P.
I found this microphone, Audio Technica ATR35S
http://www.audio-technica.com/cms/wired_mi...b3ec/index.html
Would it possible to connect the Audio Technica mic directly to the line in?
Do you think it would give a better quality recording than my current set up?
Also is there any recomendations for other small battery powered micriphones?
Thanks in Advance
