Trio3b Posted July 7, 2007 Report Share Posted July 7, 2007 Sorry, could have sworn I saw a Yamaha MD forum in here but after registering I can't find it! New to MD. I found this unit and one disc in what appears to pristine condition. Fired it up today.I have Yamaha MD4 with a 144 mb MD. shows blank data disc inserted. Recording seems fine, mono signal into channel one/group 1-3 punched/pan left/gain @11 oclock/fader at about 7 /group 1-3 monitor select. Meters show recording is taking place. After recording, as per user manual I hit "last record search" IN and playback is just flashing. When I hit play button as per directions....nothing. these leds are flashing.... as though in some standby mode.S markerPlay ledin markerabout 30 sec later the readout jumps to 72 frames then about 30 sec later timer jumps to 2 seconds. But no meter readout. Is this because I have a data disc? Sorry about the newb questions.Thanks Quote Link to comment Share on other sites More sharing options...
bobt Posted July 7, 2007 Report Share Posted July 7, 2007 I Just checked the equipment browser, this deck can use data discs, or regular MD's, regular MD's are two channel, data full use. Do you have a regular SP disc you can put in and see if that works on playback? Failing that try a mono into four track and see what happens. Try PM'ing guitarfxr, I believe ha has a similar unit.Good luck, and welcomeBob Quote Link to comment Share on other sites More sharing options...
Richard Posted July 7, 2007 Report Share Posted July 7, 2007 * Moved to appropriate sub-section Quote Link to comment Share on other sites More sharing options...
