kino170878 Posted July 12, 2007 Report Share Posted July 12, 2007 (edited) Sometimes when I insert a blanked minidisc (which previously had legacy or Hi-MD recordings on it) into my RH710, it says "Disk read error". Nothing works, and I can't record in Hi-MD mode anymore. This has happened two or three times already on separate discs. I thought that the minidisc technology was supposed to be backwards compatible? After this happens, the disc will still work on my old system. It will never work on the Hi-MD unit whatever I try.If I do any operations with the disc on old MD equipment, maybe that automatically renders the disc useless in Hi-MD mode from the moment I insert it....Would the solution then be to completely separate my usage of old minidisc recorders and newer Hi-MD portable units? I think I will only blank my minidiscs with the Hi-MD player from now on. I don't want to risk trashing my rare mindiscs, they are getting harder to find. Edited July 13, 2007 by kino170878 Quote Link to comment Share on other sites More sharing options...
bobt Posted July 13, 2007 Report Share Posted July 13, 2007 Sometimes when I insert a blanked minidisc (which previously had legacy or Hi-MD recordings on it) into my RH710, it says "Disk read error". Nothing works, and I can't record in Hi-MD mode anymore. This has happened two or three times already on separate discs. I thought that the minidisc technology was supposed to be backwards compatible? After this happens, the disc will still work on my old system. It will never work on the Hi-MD unit whatever I try.If I do any operations with the disc on old MD equipment, maybe that automatically renders the disc useless in Hi-MD mode from the moment I insert it....Would the solution then be to completely separate my usage of old minidisc recorders and newer Hi-MD portable units? I think I will only blank my minidiscs with the Hi-MD player from now on. I don't want to risk trashing my rare mindiscs, they are getting harder to find.try initializing or formatting and see what happensBob Quote Link to comment Share on other sites More sharing options...
bobzilli Posted July 13, 2007 Report Share Posted July 13, 2007 I've been through that myself and reformating always does the trick Quote Link to comment Share on other sites More sharing options...
Sparky191 Posted July 13, 2007 Report Share Posted July 13, 2007 I suppose its like any disk or harddrive after a while it just needs a format to fix all the error thats occur when its been written and rewritten over and over for a long time. I wonder do any PC hardrive defrag, fixing utilities work on MD/HiMD once hooked up to a PC. Quote Link to comment Share on other sites More sharing options...
kino170878 Posted July 13, 2007 Author Report Share Posted July 13, 2007 Reinitializing did the trick, thank you. I still wonder what the cause of the error is. Quote Link to comment Share on other sites More sharing options...
BobS Posted July 13, 2007 Report Share Posted July 13, 2007 I would expect the problem occurs when you are in HiMD mode since the PC cannot access the disk in MD mode. Checkdisk can run on a HiMD but it takes a long time and will post errors even on a good disk. Better off not doing it. If it did fix a file, your audio would probably be lost.If you use a disk in HiMD mode for data only, you can also format it in FAT32 which will help in storing more small files on a disk. HiMD looks just like any other USB storage device. Do not try defrag, you will wear your MD and it will take a very long time. You will also gain nothing since MDs have buffers to take care of audio file fragementation.I have found my JB920 deck will erase a HiMD format original disk and convert it back to an MD format disk with no problem. Quote Link to comment Share on other sites More sharing options...
