johnny7528 Posted August 17, 2007 Report Share Posted August 17, 2007 (edited) HelloI would like to replace the battery in my N10, because the battery barely stays fully loaded for a couple of minutes. I found a passage about battery removal in the manual [ http://minidisc.org/manuals/sony/sony_mzn10_manual.pdf ]; anyway the instructions given are in order to remove the battery and then dispose of the minidisc, which isn't quite what I had in mind. Or is it the same way to just replace it anyway?An what about buying new batteries? I found this offer on Ebay 1) and I'm not quite sure, if it's a good idea to buy those things over Ebay; has anybody got any experiencies on that? Or are there even other types of batteries around, which last longer?1) http://cgi.ebay.ch/SONY-3WMB-Akku-fuer-MD-...1QQcmdZViewItem Edited August 17, 2007 by johnny7528 Quote Link to comment Share on other sites More sharing options...
Richard Posted August 17, 2007 Report Share Posted August 17, 2007 * Moved to relevant sub-section Quote Link to comment Share on other sites More sharing options...
sector001 Posted August 17, 2007 Report Share Posted August 17, 2007 the battery might be fakes, cuz of it's low price. i have bought some when i had the RH1, but they do work. and I never had a problem with them.if the manual shows u how to take the battery out for disposing of the unit, then i don't see why u can't just put in another battery... Quote Link to comment Share on other sites More sharing options...
MandoRod Posted August 18, 2007 Report Share Posted August 18, 2007 The whole story on replacing an MZ-N10 battery is here.Oops! I should have tested that link more thoroughly. The thread is all there, but without the very helpful photos. Sorry.R. Freeland Quote Link to comment Share on other sites More sharing options...
johnny7528 Posted August 18, 2007 Author Report Share Posted August 18, 2007 thanks for the link, though too bad there ain't no picturesanyway I'll keep the battery for a while and if it gets worse I'll give it a shot. Quote Link to comment Share on other sites More sharing options...
