kino170878 Posted September 18, 2007 Report Share Posted September 18, 2007 (edited) I am looking to buy an Aiwa minidisc off ebay and the buyer says that he will be recalibrating it before sending it. What exactly is recalibrating a minidisc recorder supposed to do? Something regarding the laser I assume....? Edited September 18, 2007 by kino170878 Quote Link to comment Share on other sites More sharing options...
THIS SUCKS Posted September 18, 2007 Report Share Posted September 18, 2007 its an auto calibration done in service mode. usually but not always it means the unit was not working properly. be careful to make sure all the record and play functions work when you get to try it. specifically try several disks you recorded on another unit and make sure they dont skip! Quote Link to comment Share on other sites More sharing options...
Strungup Posted September 18, 2007 Report Share Posted September 18, 2007 I am looking to buy an Aiwa minidisc off ebay and the buyer says that he will be recalibrating it before sending it. What exactly is recalibrating a minidisc recorder supposed to do? Something regarding the laser I assume....?The Aiwa discs are not that good , always had some problems , I would stay away from that one . Especially if he has to "Do Something " to it before sending it . ....doesnt sound good to me . Quote Link to comment Share on other sites More sharing options...
