triflesterms Posted October 16, 2007 Report Share Posted October 16, 2007 HiIve just transfered some tracks using net md in sonic on to some mds, they play in recorder but not in my car, the mini discs i got with my new car play ok in the car, ive tried new discs at all 3 speeds with no luck, i can see text & see they are playing, but zilch as far as sound goes???Hope someone can help? thanksPs car player is sony MDX C 5970 Quote Link to comment Share on other sites More sharing options...
raintheory Posted October 16, 2007 Report Share Posted October 16, 2007 By "3 Speeds" I assume you mean LP2, LP4, and SP "Compatibility" Modes?I don't think that model is MDLP, so LP2/LP4 won't work regardless. SP "Compatibility" mode should work though... What version of SonicStage are you using?If your portable has a line or mic input, try recording a test track in realtime using the portable itself in SP mode and see if that works. Quote Link to comment Share on other sites More sharing options...
triflesterms Posted October 16, 2007 Author Report Share Posted October 16, 2007 By "3 Speeds" I assume you mean LP2, LP4, and SP "Compatibility" Modes?I don't think that model is MDLP, so LP2/LP4 won't work regardless. SP "Compatibility" mode should work though... What version of SonicStage are you using?If your portable has a line or mic input, try recording a test track in realtime using the portable itself in SP mode and see if that works.Im not sure if my car player has 3 speeds or not, though i did spot lp on the display one time by pressing a few buttons, but havent been able to get back on since, im using sonic 4.3, i already tried recording in real time though not sure if i did it in sp mode, though i did with sonic Quote Link to comment Share on other sites More sharing options...
THIS SUCKS Posted October 16, 2007 Report Share Posted October 16, 2007 you apparently did not transfer the files as sp. in the transfer window click the tool box and choose transfer as sp and then try it again. Quote Link to comment Share on other sites More sharing options...
raintheory Posted October 16, 2007 Report Share Posted October 16, 2007 If you try to play a disc recorded in LP2/LP4 in a non-MDLP player, the unit will display "LP: (track title)". Try what A WHOLE LOT states and be sure to set your transfer as "SP Compatibility Mode". Quote Link to comment Share on other sites More sharing options...
Strungup Posted October 16, 2007 Report Share Posted October 16, 2007 HiIve just transfered some tracks using net md in sonic on to some mds, they play in recorder but not in my car, the mini discs i got with my new car play ok in the car, ive tried new discs at all 3 speeds with no luck, i can see text & see they are playing, but zilch as far as sound goes???Hope someone can help? thanksPs car player is sony MDX C 5970I think the Car plaers only play SP mode , and then that Has to be from an MD recorder not the computer I have a freind here in Japan that has MD in the Car , but I have to be carefull about what discs I give him. Quote Link to comment Share on other sites More sharing options...
triflesterms Posted October 17, 2007 Author Report Share Posted October 17, 2007 I transfered it in sp in sonic & i thought that would do it, but i didnt think i would have to change setting on md player, i tried a live line in in sp & that did the trick, i would of thought even older md players would have at least 2 speeds?Is it better sound quality to record live or transfer with sonic? Quote Link to comment Share on other sites More sharing options...
KJ_Palmer Posted October 17, 2007 Report Share Posted October 17, 2007 Live recording to SP (in real-time) would give far better quality. Sonicstage can only deliver LP2 quality at best to standard MD's (even 'SP' is the reduced LP2 quality - padded out to make it work in SP players). Quote Link to comment Share on other sites More sharing options...
