ladinde Posted February 28, 2006 Report Share Posted February 28, 2006 Help! I can't open GYM. I just installed GYM, following the instructions on the website. I keep getting this error message: "an unhandled exception has occurred in your application..."If I click continue, I just keep getting same error message, and can't open the program.Please help!Thanks. Quote Link to comment Share on other sites More sharing options...
JSP62 Posted February 28, 2006 Report Share Posted February 28, 2006 ladinde said: Help! I can't open GYM. I just installed GYM, following the instructions on the website. I keep getting this error message: "an unhandled exception has occurred in your application..."If I click continue, I just keep getting same error message, and can't open the program.Please help!Thanks.Do you have all the other programs installed?MP3 Filemanager ?MS Net 1.1 ? Quote Link to comment Share on other sites More sharing options...
ladinde Posted February 28, 2006 Author Report Share Posted February 28, 2006 Yes, I do... Quote Link to comment Share on other sites More sharing options...
JSP62 Posted February 28, 2006 Report Share Posted February 28, 2006 ladinde said: Yes, I do...Don't get mad, these are just some simple questions, but you wouldn't believe people forget.Did you run the Keywizard?Is your player connected? Quote Link to comment Share on other sites More sharing options...
Guest Stuge Posted February 28, 2006 Report Share Posted February 28, 2006 ladinde,Put the crack number equal to the number of tracks in Keywizad procedure. Quote Link to comment Share on other sites More sharing options...
ladinde Posted February 28, 2006 Author Report Share Posted February 28, 2006 Yeah, I ran keywizard, device is on...Stuge,What do you mean by "Put the crack number equal to the number of tracks in Keywizad procedure"? I'm not a computer expert, so if you could explain in laymen's terms, that would be great... Quote Link to comment Share on other sites More sharing options...
Guest Stuge Posted February 28, 2006 Report Share Posted February 28, 2006 I think i didn`t clear myself there .I mean to say that when you are asked to "How many files do you except to have in your network walkman? then write the exact or more number of files that you except in your network walkman .Also GYM doesn`t play Atrac files only mp3. Quote Link to comment Share on other sites More sharing options...
ladinde Posted February 28, 2006 Author Report Share Posted February 28, 2006 I gotcha...I already did the keywizard thing. I understand it won't play Atrac. However, for the moment, I can't even open GYM...Should I try the previous version of GYM???Otherwise, once I get GYM up and running, do I just place the icon on the desktop - i.e. no install? Or is keywizard the install? To be clear - where exactly do I put the program?Thanks again... Quote Link to comment Share on other sites More sharing options...
