vicalam Posted March 6, 2006 Report Share Posted March 6, 2006 i using my A1000 to playing the album, when the album finished, the machine cannot skip to next album automatically.I need to control the player to next album.Is it able to solve this problem?Because on my old HD5, it can do it automatically.Thanks Quote Link to comment Share on other sites More sharing options...
0 Dinko Posted March 7, 2006 Report Share Posted March 7, 2006 Unfortunately, no.The new A1000/A3000 players do not automatically play the next album.Your best solution is to create a playlist with all the albums you want to play in back-to-back order. Quote Link to comment Share on other sites More sharing options...
0 Ascariss Posted March 9, 2006 Report Share Posted March 9, 2006 As Dinko mentioned, this is not possible, maybe with future firmware updates but for now just use playlsits.I would suggest making the album playlists in winamp then importing them into connect player, it might take a few seconds to a few minutes depending on your PC speed.Once it is imported, just move it over to the player. Quote Link to comment Share on other sites More sharing options...
vicalam
Thanks
2 answers to this question
