xswzaq Posted December 25, 2007 Report Share Posted December 25, 2007 As a relative newcomer to the forum, can someone explain to me the differences between the NH1 and RH1 or RH910, to be used to record lectures in class and to record practice and jam sessions? Most appreciative. I went to the charts, but except for them using different batteries and remotes, what else ?Thanks, RC Quote Link to comment Share on other sites More sharing options...
Strungup Posted December 25, 2007 Report Share Posted December 25, 2007 As a relative newcomer to the forum, can someone explain to me the differences between the NH1 and RH1 or RH910, to be used to record lectures in class and to record practice and jam sessions? Most appreciative. I went to the charts, but except for them using different batteries and remotes, what else ?Thanks, RCThe battery for the RH1 is more difficult to get , and the RH 1 is the one for Uploading Old recordings from earlier models of MD , the gumstick battery of the other two are cheaper and readily available, whereas the RH1 battery is about 5,000 yen here Quote Link to comment Share on other sites More sharing options...
greenmachine Posted December 25, 2007 Report Share Posted December 25, 2007 The RH1 and NH1 both use the same expensive battery (LIP-4WM). Only the RH910 can be powered by gumstick/AA. NH1 is first generation HiMD, RH910 second and RH1 third. NH1 cannot play mp3s, RH910 with a bug, RH1 mp3 playback is ok. The differences in recording quality are said to be marginal. Quote Link to comment Share on other sites More sharing options...
Avrin Posted December 25, 2007 Report Share Posted December 25, 2007 (edited) The RH1 is still the best unit for recording, since it remembers recording settings, instead of resetting them each time you press the stop button. Although the RH910 is much more convenient as a portable player. Edited December 25, 2007 by Avrin Quote Link to comment Share on other sites More sharing options...
Superbaldguy Posted December 25, 2007 Report Share Posted December 25, 2007 The lithium cell for the NH1/RH1 is more expensive, but far superior to the NH-14WM gumstick cell that has somewhat poor performance, IMHO. I am still using my LIP-4WM on the NH1 that I got two years ago, works sterlingly. I find the NH-14WM gets about a year, tops, before it starts to go downhill. Quote Link to comment Share on other sites More sharing options...
Strungup Posted December 25, 2007 Report Share Posted December 25, 2007 The RH1 is still the best unit for recording, since it remembers recording settings, instead of resetting them each time you press the stop button. Although the RH910 is much more convenient as a portable player.Actually I will agree with this one , I do appreciate that it remembers the settings as well. Quote Link to comment Share on other sites More sharing options...
Avrin Posted December 25, 2007 Report Share Posted December 25, 2007 Superbaldguy, get a couple of GP gumsticks, complete with a charger. You'll want to forget about anything Li-ion. Quote Link to comment Share on other sites More sharing options...
bobt Posted December 25, 2007 Report Share Posted December 25, 2007 As a relative newcomer to the forum, can someone explain to me the differences between the NH1 and RH1 or RH910, to be used to record lectures in class and to record practice and jam sessions? Most appreciative. I went to the charts, but except for them using different batteries and remotes, what else ?Thanks, RCFor recording lectures your easiest route if you don't want to take the RH! might be BIGHMW's NH-800 that he has for sale here in the classifieds, it takes AA batteries if I remeber right, and will also upload to your puter. The NH1 will work great as well, but you definately need the RMK-40ELK remote to get the most out of it,(will do wonders on the RH1 as well). The NH1's are getting a little harder to find as well, would be worthwhile if you could find one at a good price.Have fun,Bob Quote Link to comment Share on other sites More sharing options...
A440 Posted December 26, 2007 Report Share Posted December 26, 2007 (edited) The NH1 is so tiny because it puts all its functions--battery charger, etc.--on that big round proprietary docking station. No docking station and the thing is useless. Its USB connection is also proprietary and needs a special cord. Being so dependent on accessories is more trouble than it's worth. The RH1 charges its battery in the unit itself and has a standard mini-USB connection, and is much better designed in general. The basic NH700 is actually just fine for recording. Better, if you ask me, than the RH910 because it takes a regular AA battery instead of a gumstick rechargeable. The battery makes a bulge in the back, so the unit is thicker. But it's a workhorse. But....If you've never used minidisc and all you want to do is record lectures, you don't need minidisc. Get a Samson Zoom H2 for about $200. Or get an Edirol R09 for $350 to $400. Unlike minidisc, those recorders do not require an outboard microphone--they have a stereo pair built in. (The RH1 is sometimes packaged as the MZ-M200, which is the RH1 plus a clunky Sony mic, the DS70P.) For music, you would eventually want to get a better set of outboard mics and a battery module to record through line-in, but you might be able to get away with the built-in mics on the Zoom or Edirol. And unlike minidisc, with the other recorders you can just drag and drop your recordings into your computer. Whereas with every minidisc except the RH1 (and the M10 and M100 that are virtually impossible to find), you need a PC--no Macs. You need to install SonicStage software from Sony (free and worth no more than that). And transferring your recording is a two-step process: upload and then convert to a non-encrypted format. Minidiscs are encrypted: all your recordings go into one giant file, and if that file is in any way corrupted, everything on the disc turns into useless data. It can happen. Minidisc at this point is really for longtime users who already have lots of discs recorded, and for people who need the stealthiness of separate outboard microphones and a remote control. For us, it's worth dealing with the quirks of minidisc. For your purposes, it's too much hassle.I'm not trying to shut you out of the club. If something about minidisc really appeals to you, then go for it. But I think there are alternatives now. Edited December 26, 2007 by A440 Quote Link to comment Share on other sites More sharing options...
xswzaq Posted December 26, 2007 Author Report Share Posted December 26, 2007 Thanks so much to all of you. Your responses helped a lot. I have a sort of broken 900, which I had used for both lectures and music (to record jam sessions, practice, etc.) The pitch control playback was nice for the latter. Anyway, I say "sort of broken", because I have been able to revive it by using the remote and the plug in adaptor. So I bought an RH1 for music recording, and am seeking a separate one for voice. What about (dare I say) iriver ifp 700 or 800 series ? Another student had one last semester and it worked well..... Quote Link to comment Share on other sites More sharing options...
A440 Posted December 26, 2007 Report Share Posted December 26, 2007 The Iriver 700s are more sensibly designed than the Iriver 800s. You can also look at the Iriver T30 for voice recording. There's an iRiver forum here:http://www.misticriver.net/forums.php Quote Link to comment Share on other sites More sharing options...
superboy Posted December 27, 2007 Report Share Posted December 27, 2007 I'm not trying to shut you out of the club. If something about minidisc really appeals to you, then go for it. But I think there are alternatives now.A440, I wrote a nice blog about minidisc not too long ago talking about this (it's on this forum somewhere). I have a question for you about the alternatives. Are there alternatives out there right now that can honestly replace the sound quality and reliability of the mindisc? I have an RH1 right now, but I can see myself getting something else in the future because the minidisc is essentially dead. But the sound quality of the recordings on the RH1 is excellent and I've heard it's not so great on the other flash recorders out there. Quote Link to comment Share on other sites More sharing options...
Strungup Posted December 27, 2007 Report Share Posted December 27, 2007 A440, I wrote a nice blog about minidisc not too long ago talking about this (it's on this forum somewhere). I have a question for you about the alternatives. Are there alternatives out there right now that can honestly replace the sound quality and reliability of the mindisc? I have an RH1 right now, but I can see myself getting something else in the future because the minidisc is essentially dead. But the sound quality of the recordings on the RH1 is excellent and I've heard it's not so great on the other flash recorders out there.Me not 440 , Me out of tune , but research PCM-D50 by Sony , "HiMD without the Disc " it has the stuff. Quote Link to comment Share on other sites More sharing options...
A440 Posted December 28, 2007 Report Share Posted December 28, 2007 (edited) The other more affordable alternatives are the Zoom H2 and the Edirol R09. Sound quality on playback through the RH1 is superb. And mic preamps on MD--if you're not recording something too bass-heavy for them to handle--are by all accounts considered better than those on the flash units. But the sound quality recorded on the other units should be equivalent if you go through Line-in--possibly better when recording at higher bitrates than the RH1 can use. And there's no SonicStage or encryption to worry about. Edited December 28, 2007 by A440 Quote Link to comment Share on other sites More sharing options...
bobt Posted December 28, 2007 Report Share Posted December 28, 2007 The other more affordable alternatives are the Zoom H2 and the Edirol R09. Sound quality on playback through the RH1 is superb. And mic preamps on MD--if you're not recording something too bass-heavy for them to handle--are by all accounts considered better than those on the flash units. But the sound quality recorded on the other units should be equivalent if you go through Line-in--possibly better when recording at higher bitrates than the RH1 can use. And there's no SonicStage or encryption to worry about.yeah, but it ain't MD, if I ever go for something else, it will still have some sort of physical moveable media, DAT is going cheap on ebay, might try it out. I just like moving parts, , more fun, but I do see an RH1 or M200 in my life soon.Bob Quote Link to comment Share on other sites More sharing options...
Levanel Posted January 15, 2008 Report Share Posted January 15, 2008 One thing I miss from the old school days were the external battery packs for minidisc recorders/players. The RH1/M200 lacks one. I always slap one onto my N10 whenever flying overseas on 12+ hour trips.. Quote Link to comment Share on other sites More sharing options...
