Help with CD Burning on SonicStage 4.3
Tullia
Hi,
I am having no luck trying to burn Audio CDs of the music tracks I have downloaded over the last 2 years from SonicStage. It gets to 99% and 0secs and nothing happens. My CD writer's light hardly ever comes on during the process, except at about 25% and 50%. I have tried to use SonicStages help, with no luck, and have tried to search this forum but am having difficulty. All I want to do is transfer all my music that I have bought over the years from thier store to CDs, since they are shutting the place down.
The drive works in everyother way, just wont work for this.
Any help is greatly appreciated, thanks.
In what format are your files??
Have you tried Hi-MD renderer???
  Guitarfxr said:
As a Last resort , Record from the Line out of your computer to MD , then Record to Audacity from the MD , store them as WAV , OGG , or whatever .
Mac doest do sonic stage I am glad to . Just simple WAV transfer and no DRM
on a Mac , when I upload from the RH1 , it automatically is converted to WAV . so I can imoprt directly to any editor that runs on Mac . Protools , Garage Band , Audacity , Logic , whatever .
the program that Mac uses for MiniDisc , is called "HiMD Transfer 2.0 "
My Allowable transfers are as follows:
From MD to Computer
PCM 16 bit 44.1 Khz , as long as it was recorded from Mic or Line and not Optical ( Optical PCM is not allowed)
HI SP mode recordings from any source ( Including Optical )
Hi LP mode recordings , from any source ( Including Optical )
From Computer to MD
WAV format , and MP3 of almost any bit rate direct transfer
any file in another format first must be converted to WAV.
all of the above are imported as .WAV format by HiMD Transfer 2.0 , with no DRM whatsoever .
one of the reasons I switched to Mac ( I used to be on Windows XP ) the program for MD on MAC is very simply layed out , with no extra bells and whistles . Drag mp3 or WAV files into it to put on the MD , or Import from the MD in WAV format so you can go directly to work on the audio.
  the wizard of oz said:
What? That's bad!
Not really , that is Sony's way of avoiding Copyright issues , The Analouge PCM recording is just as good , if your coming off the right kind of equipment , and it transfers just fine. Just digital copy is a clear area of endangerment for them on a legal point , I dont have a problem with it . It is the sound I need not the auto Marking , when I go record a Band for a demo CD of their Live perfomance I use the RH1 and the AT-822 , do basic track marks while recording , on the 40 elk , then bring it home , import it , get a little finer in and out regions , individual files , do the mastering ,and effect processing , then order name and number the tracks , burn them to CD for the band ,........... done!
The Irish band I just did a demo for was quite happy with the results , in fact they asked me to record a bunch more stuff for them .
Yes, well, what about those who use optical as their primary way of recording?! I'm checking that PCM issue defintely this evening.
I appreciate the thought Wiz , definately understand that , but when I make optical copies of CD's it is just for me , and the stay on MD I dont need to put them in the computer , If I want it in the computer I just put the CD in the drive and copy it directly to the computer.The disc copy in Mac OS is 32 bit Floating point up to 192khz sample rate.......... ummm the RH1 doesnt go there!
  Tullia said:
Hi,
can you burn non-drm stuff?
