Need a tuner remote for my MZ-NH700
Gonzaloif
Just want to be able to have it all in one.... radio is the thing that i´m missing...
any idea of which remote and where could i find it?
I've searched for the RM-MC40ELK remote, which was supposed to be a tunner remote, but couldn't find it for sale neither in amazon, ebay or minidisco...
any way, if someone knows something about it...
thanks
Actually you really want to get the RM-MC39LT remote, this is the same one that they include with the MZ-NHF800 Hi-MD Walkman (the NH700's twin model).
Here is where to get it: http://store.whsle.biz/product_info.php?cP...products_id=158
The 39LT also has Hi-MD-exclusive A-B control as well as everything else on that other remote that he was talking about.
As for the RM-MC40ELK, while it is not a tuner remote, it has numerous features that you won't find on other remotes, and you will find it here:
http://store.whsle.biz/product_info.php?cP...;products_id=57
I have both for my NH700 and they work absolutely teriffic.
If you own an MZ-NH700 like I do (I own three of them), you need to get both to really enjoy this unit and get the most out of it.
Thanks,
Ray Jackson
Edited by BIGHMW
Thanks for the help!
I looked over http://whsle.biz for the RM-MC39LT and the RM-MC37LT . The 39LT is about 20 US dollars more expensive than the 37LT... is it worth it? is the only difference between bothe of the the "AB" function. Any way... i´ll still probably get the 39LT.
None of them got backlight, is that right?
Well, thank again... thsi forum really works!
You want to get the RM-MC39LT. This is the correct remote for your NH700/NHF800. The 37LT came with the older NetMD units, such as the MZ-NF610/810 and other NetMD units and does not have the A -> B option on it like the 39LT does, so you are right.
The 39LT is worth every bit of the extra $20 USD, I own one as well as the 40ELK, and yes to answer your question about the remote having a backight, the 39LT is not a backlit remote, but the 40ELK (non-radio remote) is backlit.
Go ahead and get both the 39LT and the 40ELK, you can't go wrong with that, and, to paraphrase what they say on Head-Fi:
"Welcome to the MDCF, sorry about your wallet"
