Error report - An error occurred while transferring
MusicBringer
Hello folks, I have been setting up my new Win XP Pro SP2 PC and now the time has arrived when I need to install and setup SonicStage.
I have found and installed SS4.2.
I tried to transfer one of my mp3s to a HiMD, using the method I have always used on all my other PCs.
However with this attempt I got an error report.
An error occurred while transferring.
Transfers are not allowed.
Oh dear me, what have I done wrong.
I tried a search but failed to find the answer. Honest.
What can you suggest, please.
I am using a MZ NH1.
Edited by MusicBringer
As I understand it , the NH1 does not Play MP3's
http://minidisc.org/part_Sony_MZ-NH1.html
that is a first generation machine , You dont get MP3 ability until the RH710 , or 910 . ( 2nd generation and 3rd generation up )
I am not trying to play mp3s on a NH1.
NH1 is not an mp3 player.
I have used my HiMD for ages, but with SS4.0 on my old PC.
I cannot get SS4.0 to install on the new PC.
I have therefore installed SS4.2
I am trying to transfer an mp3 to HiMD using SS4.2, which means that it converts the mp3 to ATRAC3 132k.
I get this wretched error message. That is driving me mad. :crazy:
Guitarfxr, thanks for trying to help.
  raintheory said:
Try right-clicking the file after importing and converting to Atrac3 that way... Then try to transfer that.At least that will give us an idea of where to go from here,.
Hello raintheory, I tried that and got another error message.
This one in the image:
Guitarfxr, the bit rates are various, some 128, some 320, some vbr, some cbr.
Believe me I have tried all sorts.
Such as checking "read only" attribute - that's ok.
Not sure about codecs installed. As this is a new pc setup do I need to install codecs. If so how?
btw I can play mp3s on a variety of players incl SS4.2.
... and let me add that using my old pc with ss4.0 together with the same NH1 and HiMD I can transfer anything without problem. I always have been able to transfer my mp3s to my HiMDiscs without difficulty. I have done it for years and on each PC I've owned.
I get to this new PC and well, you know how I am feeling....Grrrrrrr! :aggressive:
I guess this message of "An error occurred while transferring. Transfers are not allowed." is new and not been seen before. I suppose it is a generic error message, coz it tells you nothing, other than the fact that SS will not behave..!!
Where can I get a Full copy of SS4.0 to see if that will work. I thought I had a copy myself but it is the cut down version that needs the (2005) server and that's not working now.
Thanks for trying to help me :)
Well it's 12 hours and 87 views latter.
I guess nobody uses minidisc anymore, or at least nobody who understands this error message: :closedeyes:
Surely somebody has seen it before, I cannot be the first to get this error.
Please...
:search:
Another thing to try is to strip the ID3 tags from the mp3 and then try to transfer. It's been a while but I think I recall certain tags tripping SonicStage up.
http://www.mp3tag.de/en/
Beyond that, perhaps convert the mp3 to WAV and import that...
Is it only this particular mp3 giving you trouble or all of them?
Edited by raintheory
Nice try Guitarfxr
It don't work
"Forbidden
You don't have permission to access /temp/1/SS40_MDCF.exe on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
Apache/1.3.41 Server at www.pepperonistavern.com Port 80"
  MusicBringer said:
Nice try Guitarfxr
It don't work
"Forbidden
awww man , sorry dude , it used to work , it seems like servers are changing faster than Mikkey D's financial strategies
