Recharging Cradle... lost
unlabelled
Thanks for these ideas - I'll check them out. (I did try going to the sony shop, but they wanted £45 for a replacement cradle! The guy said they would have to import it from the USA. In other words - get lost. I've had it with Sony now. They bring something out, then five years later, if the smallest thing goes wrong with it... you're on your own. I suppose you're supposed to chuck it in the bin and buy their latest product instead. They must think we're stupid.) Anyway, thanks again for your help.
SOLUTION. Turns out that if you let the battery run down to empty, THEN connect it to the mains supply (as if you were going to play a disc using the mains and 3V adaptor) THEN press 'stop'... it automatically starts to recharge the battery. So, UP YOURS SONY, you rip-off merchants!
