"Format Error Disc"
Hello,
I have an error message on my Sony Mz Nh 700 :
"format error disc" then "format to record or play ?" then "push YES : ENTER, NO : CANCEL"
What is this problem ? What does this mean ?
What should I do ? :scratchhead:
I have hours of live recordings on my HiMd and I don't want to lose the files.
Thanks for your help.
  • 10 months later...
I have the same problem - there appears to be a new (free) service from Sony Japan which recovers these discs, but I can't find the details - anyone know more?
Richard.
  carinou2005 said:
Hello,
  carinou2005 said:
Hello,
Does Sonic Stage recognize the files? What version of SS are you using, should be at least 3.4 if not 4 seriesYou can also take the battery out of your unit, at least ten minutes, then try again.
Were you editing on the disc when this happened?
Bob
