pfleming Posted August 11, 2008 Report Share Posted August 11, 2008 Hi,I'm using a Sony MD Walkman MZ-NH700 minidisc recorder to record messages from my church.Sometimes having transferred the .omg file from the minidisc to Sonic Stage (version 4.3), I have found, having right clicked the file name and clicked save in WAV format, that I get an error report:-One or more tracks cannot be saved in WAV format.Cannot save in WAV format.It is strange because sometimes it happens with a new recording and sometimes it doesn't.Can someone advice me how I can get the .omg file to save as a .wav or .mp3 so I can put it on-line.I have a 63 minute file at the moment where I got the above error message.Thanks,Peter Fleming Quote Link to comment Share on other sites More sharing options...
sfbp Posted August 11, 2008 Report Share Posted August 11, 2008 Check SS and see where the .WAV files are kept. 63 minutes is at least 500 MB maybe more like 600. If the default configuration is to put the .WAV files to some device or partition that doesn't have this much space, you might just have a problem. Look under 'Tools->Options->Location to save imported files'.It's also possible you need to defrag though I would be surprised. Something is stopping the transfer.The other (more disturbing) possibility is that you have errors on your disk that happen to get hit when you create the large file needed. Better back up soon. Quote Link to comment Share on other sites More sharing options...
pfleming Posted August 11, 2008 Author Report Share Posted August 11, 2008 Hi Stephen, Thanks for your message. The Open MG audio file is currently on my desktop and is 116 MB.Please see attached for the error message I get when I try to save in WAV format.Thanks for your help.Peter Quote Link to comment Share on other sites More sharing options...
sfbp Posted August 11, 2008 Report Share Posted August 11, 2008 Right there in the picture is the evidence.... "free 407.2 MB"You ran out of space. Just as I said. Time to clean up your disk and delete some stuff.The WAV file will be about 500-600 MBGood Luck! Quote Link to comment Share on other sites More sharing options...
pfleming Posted August 11, 2008 Author Report Share Posted August 11, 2008 Hi Stephen, Thanks for your assistance.I have deleted a few things and the wav conversion worked.Regards,Peter Quote Link to comment Share on other sites More sharing options...
A440 Posted August 11, 2008 Report Share Posted August 11, 2008 Once you have uploaded the file you can also use Hi-MD Renderer to save it as an mp3 instead of converting to .wav. It will save a lot of space.http://forums.minidisc.org/index.php?showtopic=20395 Quote Link to comment Share on other sites More sharing options...
