Sony_Fan Posted August 20, 2008 Report Share Posted August 20, 2008 There's a non-working MZ-RH1 on ebay that is being sold cheap. Here's the link, maybe someone here can buy it, fix it and sell it for a profit. I don't know how to fix stuff like this:http://cgi.ebay.com/MZ-RH1-non-working-for...1QQcmdZViewItem Quote Link to comment Share on other sites More sharing options...
Avrin Posted August 20, 2008 Report Share Posted August 20, 2008 The "It's disassembled because I took it apart to remove the jammed minidisc." statement makes it clear that the overwrite head is no longer. And there's no way to replace it. Sorry... Quote Link to comment Share on other sites More sharing options...
Sony_Fan Posted August 20, 2008 Author Report Share Posted August 20, 2008 The "It's disassembled because I took it apart to remove the jammed minidisc." statement makes it clear that the overwrite head is no longer. And there's no way to replace it. Sorry...So you're saying the seller is trying to scam somone? Quote Link to comment Share on other sites More sharing options...
Avrin Posted August 20, 2008 Report Share Posted August 20, 2008 (edited) Not at all. The seller is actually selling some electronic intestines of their RH1. And these may be of value. Edited August 20, 2008 by Avrin Quote Link to comment Share on other sites More sharing options...
Strungup Posted August 20, 2008 Report Share Posted August 20, 2008 Without the qualified equipment there isnt a way to fix it , if it isnt "Fixable" ....... If the seller has No source for Fixing , and Says it is Fixable , then it is a falsehood , if the seller just doesn't understand , then it is , then it is lack of common sense Take your pick Quote Link to comment Share on other sites More sharing options...
Avrin Posted August 20, 2008 Report Share Posted August 20, 2008 The white connecting "ribbon" at the right part of the photograph doesn't look to me as if it has anything to do with an RH1. Quote Link to comment Share on other sites More sharing options...
Strungup Posted August 21, 2008 Report Share Posted August 21, 2008 The white connecting "ribbon" at the right part of the photograph doesn't look to me as if it has anything to do with an RH1.It isnt a connecting ribbon , It is a piece of Scotch Tape folded over with the screws inside . I had to look at it fairly closely but that is what it is A common practice , I do that myself when I am repairing something Quote Link to comment Share on other sites More sharing options...
