Need battery for MZ-R35
So I'll be needing a new battery for my MZ-R35. My family just dug the unit out of a closet where it's been since 2000, but I remember the battery was dead even then after I didn't use it for six months.
I checked eBay and it seems it's all Hong Kong. Where do I get a good one? Thanks.
here ya go
http://www.camcorder-battery.org/SONY/LIP-12.HTM
this is an equivalent for a LOT less money ( I have an LIP-8 of the same company , it works fine)
Ok, I got the battery, but I realized I don't have the charger.
I went to Radio Shack and they want $33 for one.
I tried searching the internet, but I can't figure out which one I need. The unit says 6v, but my new battery says 3.6v, 2000mah.
Can anyone help me?
Thanks.
The unit says , 6 Volts , dont argue with a machine ( we are getting to close to that in todays world) !!! it needs 6 Volts . R50 is the same way 6 Volts input
Positive tip , negative sleeve , 6 Volts , 800 ma ......... that is what you need .
Edited by Guitarfxr
