Artifacts in SP recording
aidanjansen
  aidsypoo said:
hey all
stupid question but...
if im recording using the optical TOS link on my laptop to my MD in SP mode. Yet the MP3's im playing are max 256kps, will i get a lot of articfacts and stuff when listening, would you recoment just recording in LP2?
peace
If you record using the Optical out of your Macbook , you will have this problem :::
Optical out on the Mac is seen as a steady stream , No Track breaks , No track info , just a Stream , so you wont get track marks in between your tracks
If you record analouge out and your MD is set right , then in the Blank spaces between tracks a track mark will appear on the MD (Most of the time , the noise has to drop below a threshold , for a certain time period for it to do so , sometimes it misses)
SP would be fine , The Way an MD records , will ( To my ears anyway ) help correct some of the " MP3 Syndrome " Anything in MP3 already has crap in it , it is just part of the compression of MP3 , it is much better now than what it USED to be . A few years ago MP3 was just the fascination of being ABLE to shrink a file and still listen to it , sound quality had very little to do with it . Now the Coding has gotten much better , but still ..........
ATRAC will sort out its OWN frequency pattern when recording WHATEVER is coming into it , and a lot of related noise in an MP3 is seen as just that Noise , and ATRAC filters some of it out . ( I have had this experience on MANY occasions , where a not so great MP3 sounded a LOT better after I recorded it on my MD , Playing back thru my digital monitors A-> B comparison of both , I could here the difference ( we are talking 128 kbs mp3 here , your at 256 so dont worry about it)
