pbelenky Posted September 14, 2008 Report Share Posted September 14, 2008 For a while, I could make a standard transfer of MP3 files to my Sony Net MD Walkman MZ-NF610. Now, every time I try, SonicStage 4.3 gives me a message, "Select a bit rate. One or more files cannot be transferred in their current bit rate. They will be converted and transferred." This happens to all MP3s, regardless of bit rate or size and even to files I had previously downloaded. Does someone have an explanation or recommendation? Quote Link to comment Share on other sites More sharing options...
sfbp Posted September 15, 2008 Report Share Posted September 15, 2008 The NF610 doesn't play MP3 natively. Always converted to some variety of .oma.So (i've never done this, as I don't use MP3's except to make them) it's asking you which .oma file to make.You can find which one is already there, by rightclicking the files one by one and selecting "Properties", then the tab labelled "File Info".To stop giving SS a headache it sounds like you need to default the output format. Suggest LP2. It may be that it is set to " ask me every time" - and you simply can't do that when you have multiple files to transfer, it doesn't have the logic to create multiple different formats on a single transfer.Transfer setting is controlled by the buttons in the middle of the screen (or there is a fancier way from the menu but who cares?).See if this helps and if it doesn't I will try and specify the steps more exactly. Quote Link to comment Share on other sites More sharing options...
pbelenky Posted September 16, 2008 Author Report Share Posted September 16, 2008 <>Well, I inherited this MD player from my son, who had used it for several years, before he got an iPod. I told him that SonicStage insisted on converting MP3s, and he disagreed emphatically, showed me that a standard transfer could be performed without conversion and played the MP3s back from the MD. Something changed very recently.I was really hoping not to have to convert, both because the audio quality would deteriorate and because it takes a long time. Quote Link to comment Share on other sites More sharing options...
sfbp Posted September 16, 2008 Report Share Posted September 16, 2008 >Well, I inherited this MD player from my son, who had used it for several years, before he got an iPod. I told him that SonicStage insisted on converting MP3s, and he disagreed emphatically, showed me that a standard transfer could be performed without conversion and played the MP3s back from the MD. Something changed very recently.I was really hoping not to have to convert, both because the audio quality would deteriorate and because it takes a long time.I am about 99.9% sure you cannot have an NF610. Either that or SS was converting without telling you.In fact if you look in the equipment browser you will see that nothing before the RH710 had this feature, ie machines made starting in 2005 and later. Thus the vast majority do not support native MP3 playback. Quote Link to comment Share on other sites More sharing options...
