orguss Posted September 19, 2008 Report Share Posted September 19, 2008 (edited) Hi all, recently SS4.3 on my Vista could no longer transfer tracks to my MZ-N1. I never have any problems before hand. I checked and tried recording audio from both the mic and optical cable without any problem. Could it be SS4.3? After re-installing SS4.3, and I'm still not able to transfer any track.....Hmmm. If recording using the mic and optical cable not showing any problem, I'm sure the hardware itself should be working fine. I tried cleaning the USB connectors on both player and the docking station, but still nothing helps.Tried using new MD media, playing it with fresh battery and the usual cleaning of the lens too. Any help or advice would be appreciated. Thanks. Edited September 19, 2008 by orguss Quote Link to comment Share on other sites More sharing options...
Avrin Posted September 19, 2008 Report Share Posted September 19, 2008 Looks like a software glitch. May be a complete SS reinstall will help. Quote Link to comment Share on other sites More sharing options...
orguss Posted September 19, 2008 Author Report Share Posted September 19, 2008 Avrin said: Looks like a software glitch. May be a complete SS reinstall will help.Hi, appreciate the advice, tried, but in vain. Currently downloading SS4.2 via torrent, hopefully it will help in rectifying the problem. Anyone out there with solution, pls leave a msg here. Thx. Quote Link to comment Share on other sites More sharing options...
sfbp Posted September 19, 2008 Report Share Posted September 19, 2008 Isn't the MZ-N1 the machine that might offer real SP downloads?In which case, you need an OLD version of SS, instead of a new one. by "old" I mean something closer to the age of the N1.Perhaps you are expecting to do Standard Play (SP) downloads, and the most recent SS (with their "Fake LP2" version) don't allow that.I know, we've talked about this Avrin, but at the time I suggested the very earliest NetMD machines might be interesting for this reason. Of course, I don't even have one. How to diagnose this?Stephen Quote Link to comment Share on other sites More sharing options...
orguss Posted September 19, 2008 Author Report Share Posted September 19, 2008 (edited) sfbp said: Isn't the MZ-N1 the machine that might offer real SP downloads?In which case, you need an OLD version of SS, instead of a new one. by "old" I mean something closer to the age of the N1.Perhaps you are expecting to do Standard Play (SP) downloads, and the most recent SS (with their "Fake LP2" version) don't allow that.I know, we've talked about this Avrin, but at the time I suggested the very earliest NetMD machines might be interesting for this reason. Of course, I don't even have one. How to diagnose this?StephenHi Stephen, I have been recording in LP2 mode all along using SS 4.3 from my XP platform from 2006 to 2007 till early 2008 when upgraded to Vista without any problem. The problem started when MS installed a few updates including the Vista SP1 (not sure whether is this the cause or not). Do you suggest that I start recording in SP mode? Any recommendation on which version of SS should be used on Vista to work with the N1? BTW, just tried using SS4.2, and the transfer stuck at 95% too. The only way to stop the transfer is to reboot the whole PC, since the 'Stop' function on SS will not terminate the transfer Edited September 19, 2008 by orguss Quote Link to comment Share on other sites More sharing options...
sfbp Posted September 19, 2008 Report Share Posted September 19, 2008 It does seem that some update of Vista (may I guess some security/encryption issue?) killed SS. Thank goodness I never even tried it.SP on current machines is known to be "Fake SP" - and you cannot upload SP from MZ-N1 (though the RH1 will do that for you nicely). So I don't think that gets you anything. Unless you have an OLD version (pre Vista, almost pre-XP) of the software that ORIGINALLY came with the N1. I'm thinking maybe there WAS a way to get real SP onto MD with the oldest units. Quote Link to comment Share on other sites More sharing options...
MDane Posted September 19, 2008 Report Share Posted September 19, 2008 sfbp said: SP on current machines is known to be "Fake SP" - and you cannot upload SP from MZ-N1 (though the RH1 will do that for you nicely)...I'm thinking maybe there WAS a way to get real SP onto MD with the oldest units.You've peaked my curiousity. Can you explain this a little further...or give a link to an thread on this? Quote Link to comment Share on other sites More sharing options...
sfbp Posted September 19, 2008 Report Share Posted September 19, 2008 Just search here for "fake SP" Quote Link to comment Share on other sites More sharing options...
Avrin Posted September 21, 2008 Report Share Posted September 21, 2008 Somehow I don't think is has ever been possible to download real SP. AFAIK, the entire problem arose because Dolby Laboratories never allowed SONY to create a computer SP codec (SP is based on several Dolby patents).And I don't think that old SS actually downloaded WAV or PCM to older machines (to encode to SP in the unit), since it would have taken ages at their speeds (maybe even longer than realtime). Quote Link to comment Share on other sites More sharing options...
