Sony mz-nh1 "REC ERR"
skinnyboy
I'm trying to troubleshoot an error on the Sony MZ-NH1 for a friend. I know little about minidisc players, so I'll just tell you what's happening:
When I turn on the player, the display shows a spinning disc, a battery icon (2/3 full), "REC", a folder icon, and "HI-MD".
The disc can be heard starting to spin.
The word "LINE" appears for a second or two, then goes away.
A clock appears and counts up until it reaches between 7 and 10 seconds, then it's replaced by a flashing "REC ERR" for a few more seconds. After that, the unit shuts down.
The unit hasn't been used for a few months, but worked fine last time. Any ideas as to what we can do?
Sounds like it's trying to record but there is no input connected.
Sorta depends on what you're doing. Start with a disc in a known state. Put the disc in and try to play it. If it is empty it will say "Blank Disc". If not, some numbers will show on the display.
Did you try to record? If not, then maybe the record button (on most is the same thing as the T-mark button) stuck, either physically or maybe electronically? If it's the latter, maybe removing the battery and all source of power for 5 minutes might help.
I defer to those who own an NH1 (which I don't).
Have you got a manual? Should find one here online if not.
Cheers
