Looking for a Sony EH1
HEARDATBEAT
Well I saw kardon's pictorial of the Sony EH1 and I absolutely love it. :maninlove: so I hit the net looking for any place to buy it but no luck and not just this unit but every unit. The only one i can seem to find is the MZ-NH600d which I have and the RH1 which for some reason i don't like. So I wanted to know if there is anyone or anyplace where i can find this unit cause I really want to update cause i've had the 600D forever and i feel i need to upgrade. Anyone willing to help me out would find me at their feet.
Just out of curiosity, what's your problem with the RH1? I like most of the HiMD units that came before it, but I use the RH1 just for uploading and live recording, since all the reports are that it has a limited lifespan - particularly the jog lever which seems to wear out.
THe 600D has a problem, it cannot record its only music from external sources. But the 600 is a perfectly good unit and I or others here can point you in the direction of one. A second hand HiMD unit will set you back $100+ these days, a good HiMD (the NH1 is everyone's favourite) $200 or more.
Where are you located?
Stephen
Stephen
I don't like the battery life, to me that's a deal breaker but I was reading the EH1 capabilities and it's battery life is a little better than the RH1, and now you are telling me that the lifespan is limited so that's one more reason I don't like the RH1. I kinda had an idea that i might not be able to get the EH1 new so if I can find one that in good condition I will purchase it. Plus I like that little woosh design it has on the cover and the remote RM-MC40ELK. And for location I am located in Washington, United States.
Edited by HEARDATBEAT
The only new unit available is the RH1. However someone is remaindering the DN430 (NetMD, from about 2005, you won't even find it on the equipment browser here) and you can probably pick one up in an ebay auction for $20.
If you want/need HiMD, most people including me swear by the 700/800/900 series (be sure the name has an H in it, or you get the pre-HiMD units only).
