mz-nh1 to wave - pc
El Eddie
  El Eddie said:
i wont rant over the obvious stupidity from Sony not letting you upload directly to you PC your files or convert to wave with the monstrous programs they release for such a basic feature.
Just want to know if anybody has heard of a way to upload your files without that crap of sonicstage?
Yes, it's called straight time in through your soundcard. What is your problem? If it is a recording done on your NH1, it is a very simple job to upload, if it isn't, then you need the RH1, no problem it isn't SS's fault, you knew the limitations when you got the machine,
Bob
