Etymotic ER6i question
HEARDATBEAT
I just bought some Etymotic ER6i headphones and I am loving the mids and highs but the lows dissapointed me a bit so i started searching and the best way to up that bass was to get an amp. what type of amp do you guys suggest to get with these headphones?
I was looking at the CMoy amps and they seem to do a good job as anyone had any experience with these or recommend me a good portable amp for these phones.
  HEARDATBEAT said:
I just bought some Etymotic ER6i headphones and I am loving the mids and highs but the lows disapointed me a bit so i started searching and the best way to up that bass was to get an amp. what type of amp do you guys suggest to get with these headphones?
Sorry, I can't advise you about amps, but can I suggest that if you have an adjustable equaliser on your player, you give this a try first.
I find with my ER6s that they sound terrible on the Normal setting, but OK if I have the settings as follows (from left to right):
100Hz: +3
250Hz: +2
630Hz: Flat
1.6kHz: -2
4kHz: -1
10kHz: Flat
If you do get an amp, I'd be interested to hear which one, and how much difference it makes.
100Hz: +3
250Hz: +2
630Hz: Flat
1.6kHz: -2
4kHz: -1
10kHz: Flat
i'm gonna get it and i'll let you know how it turns out. Imma get the CMoy bass boost amp in an altoids tin
The Etymotics do need a little more power , they were designed originally as in ear monitors for stage use . and that means coming from a Headphone driver with pro level power
Consumer phones are designed to use a LOT less power to achieve a moderate frequency spectrum.
with the Amp you will hear HUGE differences in details with those phones.
